D16z6 Valve SPrings, are the exhaust and intakes sides different?? interchangable?
Intake/exhaust springs have a stripe of paint on them. If I remember correctly, the intake springs have a *** stripe and the exhaust springs have a *** stripe. It's usually hard to see at first because most of the paint falls off over time.
Modified by Enzo Speed at 6:52 PM 8/18/2006
ahh so confusing, i just read a thread on d-series.org that says the reddish/brownish painted ones belong on the intake side cuz they're the stiffer ones. and the blueish/greenish ones are on the exhaust side, can someone confirm which is correct? i dont wanna put em in wrong and screw up my engine
http://www.d-series.org/forums...rings
the manual says nothing about the spring
. but yea the spring does have the 2 diff colors... can someone with a z6 open their valve cover up to see which color is on which side? bump for answer
Fine, I got off my lazy *** and went into the garage where I have 2 z6 heads lying around. Results:
-Intake springs are definitely red.
-Exhaust springs are definitely green (actually, it's more of a blue/green).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed »</TD></TR><TR><TD CLASS="quote">Fine, I got off my lazy *** and went into the garage where I have 2 z6 heads lying around. Results:
-Exhaust springs are definitely green (actually, it's more of a blue/green).</TD></TR></TABLE>
you da man enzo
you da man enzo
Fallen86
Aug 16, 2006 04:23 PM
BlueShadow
Mar 20, 2004 08:36 PM
Convoy
Dec 31, 2003 09:40 AM
Convoy
Dec 29, 2003 09:48 PM
