ITR/CTR/GSR cams..
Old Apr 25, 2002 | 02:56 PM
PnX-R's Avatar
Default ITR/CTR/GSR cams..
I don't know if anyone remembers reading this but.. 'Bout awhile back, I remember reading something about the similarities between the '00-'01 ITR cams and the CTR cams. Something about the intake cams are the same for them. And then, I also remembered somewhere that the intake cam on the GSR has the same part number as the exhaust cam on the ITR or something like that.. Can anyone clear this up for me?? I can't remember if it's the cam or springs that are the same...
Old Apr 25, 2002 | 03:06 PM
IgniteTeg's Avatar
Default Re: ITR/CTR/GSR cams.. (PnX-R)
The 00-01 Itr exhaust cams and intake are the same as the ctr however the lower year itr intake have 3° less duration as to the ctr intake. My suggestion is go with the itr cams unless you have money then get the ctr. HTH. Good luck
Old Apr 25, 2002 | 03:10 PM
B00ST2nR's Avatar
Default Re: ITR/CTR/GSR cams.. (IgniteTeg)
Get ITR or CTR cams...
Old Apr 25, 2002 | 03:12 PM
iH8RICERZ's Avatar
if you plan on going with the ctr or itr cams..try to go with a ctr intake cam and a itr exhaust cam.... but i'm also wondering about the gsr intake cam thing that you mentioned...anyone?
Old Apr 25, 2002 | 04:33 PM
ingrate's Avatar
25 Year Member
intake cam the same as the ITR exhaust cam? no way.. you must be talking about valve springs. GSR intake springs are the same as ITR exhaust springs.
PS- search is back up now
Evil DOHC's Avatar
Default Re: ITR/CTR/GSR cams.. (*****GotRice)
The Springs. The part number for cams are totally different.
EVIL
Old Apr 25, 2002 | 09:09 PM
Maxwell's Avatar
Default Re: ITR/CTR/GSR cams.. (Evil GS-R)
Check this out.... http://tiiite.b16a.com/VtecCams.htm
Old Apr 25, 2002 | 09:28 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: ITR/CTR/GSR cams.. (Maxwell)
The GSR intake cam is NOT the same as the Type R exhaust cam.
Ra GS-R
Aug 10, 2007 03:50 PM
ALLmoTorB18CrX
Jun 27, 2004 09:55 AM
JDMlyfestyle
Nov 1, 2003 06:26 PM
SoCaLNaTIvE
Sep 12, 2002 05:49 PM
Nighthawk GS-R
Mar 7, 2002 09:22 PM
