times
Old Aug 16, 2006 | 08:12 PM
importtuner07's Avatar
Default times
ok im gonna go to the drags friday night for the first time i have raced on the street but havent got timed yet i was wondering what kind of times i should expect my car is a 1994 Honda Civic Ex 2 dr B16a manual VTEC controller short shifter AEM cold air intake header 4-1 cat back exhaust custom 2 1/2 anch with high flow cat AEM fuel rail fuel pressure regulater set to 30 32 psi underdrive pulley. Eibach sportline springs Rota slipstream rims 15 inch with Cooper Zeon tires. Thanks for your help.
Old Aug 16, 2006 | 08:26 PM
DTRRACING's Avatar
Default Re: times (importtuner07)
low 14 high 13 and also depends on driver
Old Aug 16, 2006 | 08:31 PM
TeenyTymer69er's Avatar
Default Re: times (DTRRACING)
No way I think hes going 13's. I say mid to low 15's
Old Aug 16, 2006 | 08:33 PM
turbociviccoupe's Avatar
is this the 1/8 or 1/4?
vlc92189's Avatar
get your launches down.. umm shift good.. i say high to mid 14's
Old Aug 16, 2006 | 08:34 PM
Default Re: times (TeenyTymer69er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeenyTymer69er &raquo;</TD></TR><TR><TD CLASS="quote">No way I think hes going 13's. I say mid to low 15's</TD></TR></TABLE>
i agree with him..in the quarter you will probably be in the low 16 high 15...it is a coupe right? good luck man
Old Aug 16, 2006 | 08:36 PM
Default Re: (vlc92189)
its quarter mile and what is the best rpm to launch at i usually launch at 4500 or 5500 so im launch with VTEC and i usually shift at 7500 any advice is great thanks
Old Aug 16, 2006 | 08:38 PM
BOOSTED RIVAL's Avatar
Default Re: (importtuner07)
try shifting a 8000 rpm
Old Aug 16, 2006 | 08:40 PM
Default Re: (BOOSTED RIVAL)
it redlines at 7700 or 7800 and is launching at 4500 or 5500 about right
Old Aug 16, 2006 | 08:45 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">ok im gonna go to the drags friday night for the first time i have raced on the street but havent got timed yet i was wondering what kind of times i should expect my car is a 1994 Honda Civic Ex 2 dr B16a manual VTEC controller short shifter AEM cold air intake header 4-1 cat back exhaust custom 2 1/2 anch with high flow cat AEM fuel rail fuel pressure regulater set to 30 32 psi underdrive pulley. Eibach sportline springs Rota slipstream rims 15 inch with Cooper Zeon tires. Thanks for your help.</TD></TR></TABLE>
Sell your underdrive pulley, fuel rail, regulator and vtec controller... and buy a mad n0s kit you ******* ricer
Old Aug 16, 2006 | 08:47 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">it redlines at 7700 or 7800</TD></TR></TABLE>
Rev it to 8000 like we told you to or continue sucking at life and all that is driving a 1.6L high-revving shitbox engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and is launching at 4500 or 5500 about right</TD></TR></TABLE>
No. Launch at 3800 and feather the clutch.
So you have a stock B16A and you're a ricer. You'll run a mid-to-high 15 if you don't mis-shift. Also, why do you have your fuel pressure regulator set to 30psi? Did you just pull that number out of your *** or what? Reasonably sure that's supposed to be at 44psi give or take a few.
You seem misguided. I want to hurt you very badly.
Old Aug 16, 2006 | 08:49 PM
Default Re: times (G2 Speed)
not a ricer the upgraded fuel was because i was playin on goin turbo but my family had problems and needed the money my friend gave me the pulley he said it helps off the line since b16's don really have good acceleration
Old Aug 16, 2006 | 08:51 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">not a ricer the upgraded fuel was because i was playin on goin turbo but my family had problems and needed the money my friend gave me the pulley he said it helps off the line since b16's don really have good acceleration</TD></TR></TABLE>
cool, well FYI.. your pulley does nothing, you have no reason for that vtec controller.. or any of the fuel stuff... and unless your making 400hp, you don't need to upgrade your fuelrail
it back fires when i turn up the fuel pressure it doesnt back fire were it is set at
Old Aug 16, 2006 | 08:52 PM
Unceasing Measure
You "upgraded" your "fuel" by installing a fuel pressure regulator and setting it to a <u>lower</u> fuel pressure than stock? And you're telling me you're NOT a ricer?
Also, your friend needs a kick to the ball sack if he thinks a pulley is going to give you better acceleration in anything.
If it weren't for the ATS thread in appearance/cosmetic, I'd be so much more angry and hateful right now. You're lucky, sweetheart.
Old Aug 16, 2006 | 08:53 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">it back fires when i turn up the fuel pressure it doesnt back fire were it is set at</TD></TR></TABLE>
It probably backfires because you modified the fuel trim with your m4d tyt3 V-teCh controller and it's post-combusting in your super cool 2.5 inch custom exhaustzorz.
Old Aug 16, 2006 | 08:55 PM
plz turn off trial user's Avatar
Default Re: times (Archidictus)
i can cook top ramen faster than u would finish ur quater mile
Old Aug 16, 2006 | 08:57 PM
Unceasing Measure
Default Re: times (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">i can cook top ramen faster than u would finish ur quater mile </TD></TR></TABLE>
You kiss your mother with that mouth?
like i said earlier i was playin on going turbo thats why i upgraded my fuel but my family had problems and needed the money so i let them have it.
Old Aug 16, 2006 | 09:00 PM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Rev it to 8000 like we told you to or continue sucking at life and all that is driving a 1.6L high-revving shitbox engine.
You seem misguided. I want to hurt you very badly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">You "upgraded" your "fuel" by installing a fuel pressure regulator and setting it to a <u>lower</u> fuel pressure than stock? And you're telling me you're NOT a ricer?
If it weren't for the ATS thread in appearance/cosmetic, I'd be so much more angry and hateful right now. You're lucky, sweetheart. </TD></TR></TABLE>
haha...this guy is funny...hate to say it but hes absolutely right...as for the kick in the ***** part...i think your friend is past due for one...jk...dont take it seriuosly... good luck man...make sure you tell us how it goes
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 &raquo;</TD></TR><TR><TD CLASS="quote">like i said earlier i was playin on going turbo thats why i upgraded my fuel but my family had problems and needed the money so i let them have it. </TD></TR></TABLE>
Well that's very altruistic of you. Maybe instead of going to the drag strip you should be putting your car back to stock, selling your riceriffic parts and giving that money to your family as well.
makes me happy.
Old Aug 16, 2006 | 09:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">You kiss your mother with that mouth?</TD></TR></TABLE>
nope but i kiss ur moms
Old Aug 16, 2006 | 09:05 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">nope but i kiss ur moms </TD></TR></TABLE>
Old Aug 16, 2006 | 09:06 PM
they give us guns and drugs and they wanna know why we thugs,
Old Aug 16, 2006 | 09:07 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">they give us guns and drugs and they wanna know why we thugs, </TD></TR></TABLE>
