so frustrating, i need help....again
Old Aug 16, 2006 | 07:27 PM
nbcivic's Avatar
Default so frustrating, i need help....again
so> i said i got a tune up and changed
-spark plugs
-fuel filter
-spark plug wire set
-rotor/cap
this was like, 2 weeks ago, and now, out of no where, i start my car, and while starting up, i hear this squeaking/slurping/weird noise and then the car starts, after all that.
i put some fuel cleaner in there, anddd that's about it, idk what this could be, i changed belts (including timing) not to long ago, so idk.
Old Aug 16, 2006 | 07:33 PM
wheelmanbg's Avatar
Default Re: so frustrating, i need help....again (nbcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nbcivic &raquo;</TD></TR><TR><TD CLASS="quote">i hear this squeaking/slurping/weird noise</TD></TR></TABLE>
while the starter is engaged or when you just turn the key to ON?
Old Aug 16, 2006 | 07:34 PM
spoonracer84eg's Avatar
Default Re: so frustrating, i need help....again (wheelmanbg)
Maybe starter is going bad
Old Aug 16, 2006 | 07:35 PM
nbcivic's Avatar
how much is starter going to run me?
Old Aug 16, 2006 | 07:44 PM
unknown0001's Avatar
is your alternator belt too tight?
Old Aug 16, 2006 | 07:46 PM
nbcivic's Avatar
uummm, i think when the starter, cause i hear some ignition first
Old Aug 16, 2006 | 07:47 PM
Default Re: (nbcivic)
Well dont just go replacing parts unless you know its the problem. Thats just the best suggestion I can give you towards the problem without actually being there to hear it. Not sure on the price of a starter but I would get a used one.
nbcivic's Avatar
Default Re: so frustrating, i need help....again (Mr.RHTuner)
it's been working fine till now, so i don't think that's it
Old Aug 16, 2006 | 09:30 PM
nbcivic's Avatar
anyone else?
Old Aug 16, 2006 | 09:46 PM
Syndacate's Avatar
Default Re: (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Well dont just go replacing parts unless you know its the problem. Thats just the best suggestion I can give you towards the problem without actually being there to hear it. Not sure on the price of a starter but I would get a used one.</TD></TR></TABLE>
I don't even think they sell used starters - by now they're all basically remanufacturered - which I guess is as good as new.
As far as the OP goes: Sounds like one of your belts is too tight or too loose from your description (which isn't the best I might add :-P). Wouldn't be possible for you to digitally record the sound and post it someplace so others can listen, would it? Usually the best way to ask others what a sound is.
Digital camera that can record video w/ sound = fast help.
Old Aug 17, 2006 | 06:28 AM
nbcivic's Avatar
well, i've had problem with the sounds because it only does them when it feels like it, when i'm infront of a mechanic or with a camera, it's picture perfect.
but, it did do it once w/my friend, a mechanic, and he said that it's just my starter grinding a little, but it was nothing to worry about, sooooo i'll just leave it at that cause starters are a bitcH. Yep.
Panda hatch
Sep 20, 2006 05:39 PM
huepowered
Apr 20, 2006 08:18 AM
wpgcivic
23
Dec 30, 2004 08:49 AM
Pikachu
13
Oct 15, 2003 09:01 PM
AMG
Aug 14, 2003 10:12 PM
