92 gs-r want 200whp what should i get
I have a 92 integra gs-r with the b17..i already have an intake,exhaust, and ngk iridium spark plugs,new ground wire kit, and ignition wires...In order to get 200wheel horsepower what should i get next in order to achieve this goal
a good intake manifold, bigger throttlebody, new cams, bigger injectors.
<-- 220whp B18c1
if it doesn't take you there it'll be a nice boost in power from stock. or, you could also boost the motor and make well over 200whp. just depends on whether you wanna keep it N/A or go F/I, both will probably cost you about the same
<-- 220whp B18c1
Well i can tell you that i wouldn't be boosting with a 92 gsr motor, i would rebuild it regardless cause i can imagine it should have 6 digit numbers on the miles...I'll say go N/A as a excuse of rebuilding your motor...
its going to cost alot of money to build a 200whp NA b17
your best option is boost if youre on a budget
or you can get a 1.8l bottom end, build it and build your b17 head and keep it NA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">its going to cost alot of money to build a 200whp NA b17
yup..my buddy has a 202whp 1.85l motor (its a 85mm b16 block w/ the b17 crank and a custom rod/piston setup)...
he wont even tell me the total cost of his motor (cams, headwork, rmf header)...
so a NA 200whp b17 wont be cheap
</TD></TR></TABLE>yup..my buddy has a 202whp 1.85l motor (its a 85mm b16 block w/ the b17 crank and a custom rod/piston setup)...
