Which year B18B1
Old Aug 16, 2006 | 06:50 PM
MDPL8706's Avatar
Default Which year B18B1
Hello,
The engine in my car was swapped before I bought it.
PO tells me '96.
I called the Honda dealer and they told me '94.
It's a B18B1
1338807.
I need to know if it should run on OBD1 or OBD2. Thanks.
MDPL8706
Old Aug 16, 2006 | 06:52 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Which year B18B1 (MDPL8706)
What year, and model is the car?
Old Aug 16, 2006 | 07:05 PM
MDPL8706's Avatar
Default Re: Which year B18B1 (CleanLikeJdm)
It's a '93 GS-R and runs on an OBD1 P75 ECU 94/95 non-vtec teg. Harness is rigged.
I need to replace the harness and need to know if I just need an OBD1 harness or OBD2 ECU and harness.
Car isn't running right obviously. MAP sensor code. Sensor replaced, still code, IACV wire cut etc. plugs all wired together (not plugged).
MDPL8706
Old Aug 16, 2006 | 07:17 PM
Hype-R Stalker
If you have an obd1 harness setup right now, for the non-vtec motor,
Then you can leave it just like that, only difference with the newer motor(if it's a 96)
All you do to make it odb1, is change a few parts, like dizzy, alternator, and injectors.
But pretty much, if it's 96+ motor, and if you have those obd1 parts, the engine won't know the difference, long as you have the right ecu/harness setup.
:edit:
Also, if the valvecover has NOT been changed, you can easily tell the year range.
:taken from the vc cover thread:
96+
95, and before.
Old Aug 16, 2006 | 07:21 PM
SmogKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDPL8706 &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
PO tells me '96.
It's a B18B1
1338807.
Dealers right, it's OBD1 94'
MDPL8706</TD></TR></TABLE>
Old Aug 16, 2006 | 07:22 PM
MDPL8706's Avatar
It looks like an OBD2 harness actually. There's two plugs dangling by the Ecu... since OBD2 ECU has 5 instead of 3 plugs right?
I think I'll need to buy an OBD1 harness and see what that does.
Can I check the number on the dizzy for example and see if it's an OBD1 or OBD2 dizzy? The timing is fully retarted (dizzy moved all the way towards the front of the car). I tried putting it in middle and the car bogged crazy.
MDPL8706
Old Aug 16, 2006 | 07:23 PM
MDPL8706's Avatar
Default Re: Which year B18B1 (SmoGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoGuy &raquo;</TD></TR><TR><TD CLASS="quote">Dealers right, it's OBD1 94'</TD></TR></TABLE>
Thanks!
MDPL8706
Old Aug 16, 2006 | 07:31 PM
MDPL8706's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">If you have an obd1 harness setup right now, for the non-vtec motor,
:edit:
96+
95, and before.
Cool. It's the 94-95 valve cover. It's been painted gold... so ummm, well, lets hope it's the original cover, but I'm preety sure now that it's a '94 engine now.
Thanks for the help!
MDPL8706
Choy
Feb 25, 2010 03:07 PM
vtecftw
Aug 11, 2007 11:15 AM
myEK=slow
11
Aug 21, 2006 08:20 PM
pane93civhb
Feb 15, 2005 12:35 PM
superfuji57
Mar 15, 2004 02:23 PM
