ecu code....someone help!!
Old Aug 16, 2006 | 06:03 PM
hondaz6ex's Avatar
Default ecu code....someone help!!
my brother has a 95 civic dx with a sohc vtec zc motor and we just got done wiring up the vtec and and vtec light.....well everything is working fine 1st and most of second gear the vtec is engaged but at the very end of 2nd the check engine light comes on and the vtec light goes off. someone told me that i have a auto. ecu?? anyone have any ideas
Old Aug 16, 2006 | 06:05 PM
unknown0001's Avatar
Default Re: ecu code....someone help!! (hondaz6ex)
There is no vtec light...it's the check engine light
did you check the car for what the code is?
what does it say on your ecu??? p28?
Old Aug 16, 2006 | 10:24 PM
hondaz6ex's Avatar
no i wired up a vtec light and yes it workes intil the end of second gear then the check engine light comes on...and yes i am running a p28 but i am wordering if by any chance it could be a automatic p28 causing it!?!?
Old Aug 16, 2006 | 10:25 PM
amy's Avatar
amy
Default Re: (hondaz6ex)
it could be caused by being an automatic ecu
if you want to open up your ecu and look to see the difference, it's in the lower right hand corner of the ECU
i would say your best bet is to check your code by following instructions from the first post here:
https://honda-tech.com/zerothread/1171263
Old Aug 17, 2006 | 08:25 AM
hondaz6ex's Avatar
alright thanks i will take a look and let ya know
Old Aug 17, 2006 | 08:07 PM
hondaz6ex's Avatar
checked the ecu and it a manual. and i just checked the code and itz code 22...how can i check the vtec pressure valve?
Old Aug 17, 2006 | 08:50 PM
egsleepercivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaz6ex &raquo;</TD></TR><TR><TD CLASS="quote">my brother has a 95 civic dx with a sohc vtec zc motor and we just got done wiring up the vtec and and vtec light.....well everything is working fine 1st and most of second gear the vtec is engaged but at the very end of 2nd the check engine light comes on and the vtec light goes off. someone told me that i have a auto. ecu?? anyone have any ideas</TD></TR></TABLE>
redo the wiring for the vtec pressure switch
Old Aug 17, 2006 | 10:47 PM
hondaz6ex's Avatar
when i wired this up was there suppose to be a ground??
Old Aug 18, 2006 | 08:48 AM
JeffBro's Avatar
yeah the vtec pressure switch must be grounded. The blue/black wire is the ecu wire and the other wire gets grounded.
Old Aug 18, 2006 | 09:04 AM
hondaz6ex's Avatar
would that cause the check engine light to come on ? i am prettty sure it would..i will post again later on how everything is going
gabriel0830
Mar 18, 2013 08:46 AM
Chicano
Nov 8, 2007 05:22 PM
nicko360
Oct 27, 2007 09:27 AM
brewbud
Nov 10, 2005 06:36 AM
Metal_SOL
Jul 16, 2002 10:23 PM
