B16 in a G2 integra?
Yes they bolt right in, it's a very good swap. What year is your teg? If it's 92-93 your better off getting the obd1 b16, if you get the first gen b16a it's obd0 and some things will have to be changed.
very easy 90-1, cheap and easy, just add four to five wires and be done
vtec pressure, ground, vtec selnoid, knock and second 02
92-3 integra, using second gen b16a is also the same way as above, (requires only four wires )
with right ecu program such as Mugen (90-1) can run only 1 wire connected to the vtec solenoid and run without any problems
