small amount inside gas tank ?
Old Aug 16, 2006 | 04:58 PM
Hondatron's Avatar
Default small amount inside gas tank ?
A friend of mine just finished repainting his gas tank(spray paint, high temp kind) and i noticed he got a little paint in the inside. the part where you put the fuel pump goes in.
is he going to have a problem once he puts gas back in it ? i said he might.
Old Aug 16, 2006 | 05:06 PM
unknown0001's Avatar
Default Re: small amount inside gas tank ? (Upperguy)
Best would be to take a cloth of paint thinner and with the gas tank empty try to clean up as much paint as you can reach for.
Otherwise if it's a thin coat of overspray, with it completely dry it shouldn't harm the engine/fuel at all. Unless he painted a thick layer, the gas might eat at it after a while and cause it to chip and flake into the gasoline.
Old Aug 16, 2006 | 05:35 PM
Hondatron's Avatar
Default Re: small amount inside gas tank ? (Mr.RHTuner)
so it should be ok ? from the looks of it it looks like its mild and not "coated" on the inside
Old Aug 16, 2006 | 05:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Upperguy &raquo;</TD></TR><TR><TD CLASS="quote">so it should be ok ? from the looks of it it looks like its mild and not "coated" on the inside</TD></TR></TABLE>
well was the gas tank empty? the mold is from the water/gas that has been there sometime.
I'd just clean up as much with a clean dry cloth and it should be perfectly fine
Old Aug 16, 2006 | 08:09 PM
Hondatron's Avatar
thank you. i relay the message. so a small amount of paint is ok no need to re seal the entire tank?
Old Aug 16, 2006 | 09:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Upperguy &raquo;</TD></TR><TR><TD CLASS="quote">thank you. i relay the message. so a small amount of paint is ok no need to re seal the entire tank? </TD></TR></TABLE>
correct
r_kage
Paint and Body
Oct 15, 2018 04:18 PM
dc5r2002
Aug 21, 2005 04:58 AM
DIY_Racing
Honda Motorcycles
Jul 27, 2004 12:56 PM
One2chi
Mar 27, 2003 09:24 AM
Volcom
Dec 12, 2001 03:18 AM
