what oem cam can u put in z6 if any?????????
Old Aug 16, 2006 | 04:24 PM
JDM_EjONE's Avatar
Default what oem cam can u put in z6 if any?????????
i have heard that u can put some oem cams in a z6 that impoves proformance better than the stock............ is this true and if so what are they??????? i not postive about this... j/w thanx
Old Aug 16, 2006 | 04:38 PM
JDM_EjONE's Avatar
anyone...... i pretty sure i have heard this somewhere
dohcVTECeg2's Avatar
Default Re: what oem cam can u put in z6 if any????????? (JDM_EjONE)
probably a jdm d15b cam
Old Aug 16, 2006 | 04:40 PM
JDM_EjONE's Avatar
thank u.......... is there any more....... i also thank someone said that one or two dohc cams would work. not sure though
Old Aug 16, 2006 | 04:54 PM
JDM_EjONE's Avatar
any body else
Old Aug 16, 2006 | 04:57 PM
unknown0001's Avatar
Default Re: (JDM_EjONE)
not oem cams but you can throw in a zex camshaft 59300 or a crower stage 2 if you can't find an OEM cam more agressive then what you have
https://honda-tech.com/zerothread?id=1228289
Old Aug 16, 2006 | 05:00 PM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EjONE &raquo;</TD></TR><TR><TD CLASS="quote">thank u.......... is there any more....... i also thank someone said that one or two dohc cams would work. not sure though</TD></TR></TABLE>
wow who every told you that is an idiot. no none of the DOHC will work. the best thing to do would be to just buy an after market cam. ive never heard of anyone swapping cams for better performance.
Old Aug 16, 2006 | 05:23 PM
bsixteen's Avatar
Default Re: (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">
wow who every told you that is an idiot. no none of the DOHC will work. the best thing to do would be to just buy an after market cam. ive never heard of anyone swapping cams for better performance.</TD></TR></TABLE>
ppl swap in CTR/ITR cams all the time
(yes i know not in sohc but you didn't specify)
and don't forget if you go as aggressive as stage 2's you'll need upgraded valvetrain
Old Aug 16, 2006 | 05:38 PM
HXvtec's Avatar
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">
and don't forget if you go as aggressive as stage 2's you'll need upgraded valvetrain</TD></TR></TABLE>
you know what i meant
Old Aug 16, 2006 | 06:24 PM
JDM_EjONE's Avatar
ok i guess what i heard was wrong...... thank u
Old Aug 16, 2006 | 07:04 PM
WillieB's Avatar
Yes the d15b cam is a little more radical and will swap in without any problems just make sure you check valve clearance after the install
shwepes
Nov 17, 2015 09:38 PM
akshn1
Sep 29, 2009 10:01 AM
thabao
Jun 20, 2009 10:49 AM
b00sted4dr
20
Oct 9, 2004 08:15 PM
