Automatic to Manual Conversion
I need some instruction for this conversion. I have a 95 accord I am converting it to a manual. I need to know all the parts that will be required for this conversion, and if I am going to have to cut or weld to make this work.
Q about axles and tranny mount. If I am using the 5 speed tranny from the same gen, do I still need the 5 speed tranny axles(I am switching from a 92 auto to a 91 5 speed tranny)? And do I need to make any changes to the tranny mount?
Any tips for getting the axle nut off? So far it's stuck on real good.
I have the 36mm and breaker bar with an extension, so far no luck.
[Modified by jdm92accord, 10:09 AM 4/26/2002]
OK here is the stupid Q for the day: Which way do you turn the axle nut to get it off?(the drivers side front axle)
Still having trouble getting the nut off, and wondering if I am turning the nut the correct way.
dem0nk1d
Jun 7, 2007 11:13 AM
JDMvtecDRAGSTA
Mar 14, 2002 11:28 AM
auto, automatic, cb7, conversion, conversions, converting, crx, h23, hawaii, honda, manual, maual, mounts, swap, yahoo
