Automatic to Manual Conversion
Old Apr 25, 2002 | 01:51 PM
abeaujuin's Avatar
Default Automatic to Manual Conversion
I need some instruction for this conversion. I have a 95 accord I am converting it to a manual. I need to know all the parts that will be required for this conversion, and if I am going to have to cut or weld to make this work.
Old Apr 25, 2002 | 01:52 PM
H23 Power's Avatar
Default Re: Automatic to Manual Conversion (abeaujuin)
http://www.extremeredline.net/accord/automanual.html
Old Apr 25, 2002 | 06:42 PM
Nick H's Avatar
New User
Default Re: Automatic to Manual Conversion (01GSR)
dayem...sounds pretty complicated if you don't know what you're doin...you might just wanna buy a manual tranny car!
Old Apr 25, 2002 | 08:49 PM
KTeller8's Avatar
Default Re: Automatic to Manual Conversion (nickh2k1)
http://members.aol.com/accorddrv/h22.html
try that .. it should help too..
Old Apr 25, 2002 | 10:32 PM
jdm92accord's Avatar
Q about axles and tranny mount. If I am using the 5 speed tranny from the same gen, do I still need the 5 speed tranny axles(I am switching from a 92 auto to a 91 5 speed tranny)? And do I need to make any changes to the tranny mount?
Old Apr 25, 2002 | 10:57 PM
H23 Power's Avatar
Default Re: Automatic to Manual Conversion (jdm92accord)
the mount is questionable, but supposedly you have to reweld the mount
yes, you need the driver side axle and intermediate shaft
Old Apr 26, 2002 | 01:07 AM
Any tips for getting the axle nut off? So far it's stuck on real good. I have the 36mm and breaker bar with an extension, so far no luck.
[Modified by jdm92accord, 10:09 AM 4/26/2002]
Old Apr 26, 2002 | 07:40 AM
SOHCArchangel's Avatar
the nut is staked, did you punch the stake out?
Old Apr 26, 2002 | 08:04 AM
H23 Power's Avatar
i used a 6 ft breaker bar...came off really easy
Old Apr 27, 2002 | 08:05 PM
OK here is the stupid Q for the day: Which way do you turn the axle nut to get it off?(the drivers side front axle) Still having trouble getting the nut off, and wondering if I am turning the nut the correct way.
Old Apr 27, 2002 | 08:34 PM
H23 Power's Avatar
counterclockwise
DA3
Apr 18, 2008 02:55 PM
K0SDAYG
Dec 23, 2007 02:09 AM
dem0nk1d
Jun 7, 2007 11:13 AM
Skank_aSS_Dara
Apr 27, 2005 06:23 PM
JDMvtecDRAGSTA
Mar 14, 2002 11:28 AM
