Z6 help!!
alright.. so i blew my engine up last week.. i got a D15B2 to replace the Z6 bottom end.. no problems.. swap went fine.. except that i still cant get the crank pulley off to change the timing belt.. anyways.. its all back together minus a few sensors on the intake manifold..
1. i have 2 plugs that fit on the tps and are right next to each other on the harness.. one is grn yell white and the other is grn yel red.. where do they go?
every sensor is plugged in to somthing and i cant find something to plug these into ...
2. i read somewhere that you can get that bolt off by putting the power bar against the hard ground and bummping the starter.. but if my calculations are correct, this is just gonna make it tighter?? isnt that true?? i have a friend with a good impact thats gonna come over tommorow, but id like to get this thing off tonight so i can get back on the road ASAP.. lemme know guys..
and YES I SEARCHED.. there were no good posts to look at
travis
travis
yes its manual.. ive done all the tips and tricks without using air and its not working.. im not too concerned about the bolt, but the sensors are more important.. i can get the bolt off when my friend comes over
update.. the crank pulley came off with a chain clamp jammed on the uipper mount and with 205 lbs of me on the end of a 6 foot pole = the loudest bolt break that iv eheard in a while.. so the timing belt is on and tensioned and new pulley is in.. now i need the help with the connectors.. help me oput!!
Travis
Travis
help me!!!!!! I HAVE THIS EXTRA SENSOR PLUG.. ITS SUPPOSED TO BE FOR THE MAP SENSOR BUT I ALREADY HAVE ONE PLUGGED IN TO TEH MAP.. THIS IS A D15b7 CAR WITH A z6 IN IT.. ITS GOT THE b7 THROTTLE BODY WITH NO MAP AND THE MAP IS ON THE FIREWALL WITH A PLUG ALREADY GOING INTO IT.. WHAT IS THIS PLUG FOR... GREEN YELLOW AND WHITE... FITS THE TPS AS WELL BUT THE TPS IS GREEN YELLOW RED... HELP ME...
Modified by lsturboguy at 11:21 AM 8/17/2006
alwaysbroken
Feb 5, 2009 10:12 PM
00slowcivic
Jun 26, 2007 12:02 PM
Forty04
Apr 24, 2007 06:48 AM
shauniewalnuts
Jun 27, 2005 08:20 PM
