quick question on 99-00 si cluster
Old Aug 16, 2006 | 01:20 PM
young noob's Avatar
Default quick question on 99-00 si cluster
hey honda-tech, i got a 99-00 si tach for my 96 cx, and when i bought it a year ago and installed it, there was a mainenance required light that was amber red, like the rest of the cluster, i just got back from vaca. i went to drive the car and it was green, so im wondering which means maintenance is required, when its red or green, thanks
Old Aug 16, 2006 | 02:31 PM
johnecon2001's Avatar
Default Re: quick question on 99-00 si cluster (young noob)
it'll transition from green to orange to red. Red means bad. Which would be maintenance really required.
Old Aug 17, 2006 | 06:55 AM
slowcivic2k's Avatar
Default Re: quick question on 99-00 si cluster (johnecon2001)
all that marker is for is for emissions equipment inspection, and replacement if needed, all it is for it to ensure it gets to the dealer to ensure all emissions gear still works.
Old Aug 17, 2006 | 04:13 PM
young noob's Avatar
Default Re: quick question on 99-00 si cluster (slowcivic2k)
alright thanks guys, caz i got my emissions tested and it was the same color as the rest of the cluster.........amber, i haven't seen it deep red though, but it all the sudden changed to green, so i guess thats a good thing, thanks again, it was just kinda bugging me
Old Aug 17, 2006 | 04:15 PM
EFstyle's Avatar
im pretty sure you can just take a key and push in a little button on the cluster and it will reset and turn it green again
Old Aug 18, 2006 | 09:52 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: (EKEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKEJ6 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure you can just take a key and push in a little button on the cluster and it will reset and turn it green again</TD></TR></TABLE>
This is true.
The maintenance required square doesn't really mean anything, it's just a reminder on a 7,500 mile counter. It turns orange around 7000 and red at 7500. I'm not sure what it's supposed to remind you of. You can reset it to green by pushing the little rectangular button next to it.
Old Aug 18, 2006 | 11:22 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">all that marker is for is for emissions equipment inspection, and replacement if needed, all it is for it to ensure it gets to the dealer to ensure all emissions gear still works.</TD></TR></TABLE>
wrong
the maintance rec light goes stricktly off milage. has nothing to to do with emmissions, rather that the car is do for a maintance interval. sometimes that is just a oil change, rotate, and brake inpection. other times it meansyou need more major stuff including trans service, coolant drain/fill, valve ajustment etc. check your owners manual or dealer to see what is rec at your currant milage. and yes the key in the cluster thing will turn it green again.
GreddyCivic7
17
Apr 13, 2007 05:39 PM
turbo Si
Mar 4, 2006 04:55 AM
eJ6DM
17
Dec 22, 2005 06:40 AM
EK9 BEEZLER
Jul 19, 2005 03:25 PM
J337_UNIT
Apr 12, 2003 03:57 AM
