obd2 swap question
Old Aug 16, 2006 | 01:12 PM
error's Avatar
Default obd2 swap question
swapping in a 98 b18b motor into my 96 hatch. can some one explain the whole crank angle sensor and iacv fix to me? help, car wont start!
Old Aug 16, 2006 | 01:19 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd2 swap question (error)
http://www.ff-squad.com/technet/
Old Aug 16, 2006 | 01:22 PM
error's Avatar
Default Re: obd2 swap question (HondaPartsHero)
ok, but how do i tell if i am obd2a or obd2b? im using obd2 ls ecu and i understand there is a problem with the iacv with this swap also?
Old Aug 16, 2006 | 01:27 PM
error's Avatar
i also have my vafc2 wired up still. will this effect anything? i really need to get this thing going. it will not start. is this normal for a car not to start without the crank sensor fix? ive read that it will just run like crap.
Old Aug 17, 2006 | 10:33 AM
error's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/technet/</TD></TR></TABLE>
wait, i have a usdm motor and ecu. shouldnt it start anyways without the ckf?
Old Aug 17, 2006 | 10:51 AM
:Andrew's Avatar
the iacv pinout trick is not necessary on a non vtec swap. also do you have a ckf sesnsor on your motor? if your motor is a 98 and its usdm you should have one. I think your problem lies elsewhere.
Old Aug 17, 2006 | 10:59 AM
error's Avatar
Default Re: obd2 swap question (:Andrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :Andrew &raquo;</TD></TR><TR><TD CLASS="quote">the iacv pinout trick is not necessary on a non vtec swap. also do you have a ckf sesnsor on your motor? if your motor is a 98 and its usdm you should have one. I think your problem lies elsewhere.</TD></TR></TABLE>
im thinking so.... gotta get this thing rolling in less than 2 weeks.
Old Aug 17, 2006 | 12:31 PM
:Andrew's Avatar
are you getting spark?
Old Aug 17, 2006 | 04:27 PM
error's Avatar
yeah i have spark. fuel preassure is around 40. im kinda stuck here. how do you check if the injectors are working? or should i check compression first?
Old Aug 17, 2006 | 04:58 PM
error's Avatar
rather than testing the voltage of the injectors, can i just take off the fuel rail and pull the injectors out and see if they are squirting? will i have any sealing problems when i put them back in?
Old Aug 17, 2006 | 05:42 PM
error's Avatar
OMG LOOSE GROUND WIRE@#$%@!$# starts right up now. only the idle is way up there in the 4000's. maybe because i put the tps in wrong?
Old Aug 21, 2006 | 12:48 AM
:Andrew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">OMG LOOSE GROUND WIRE@#$%@!$# starts right up now. only the idle is way up there in the 4000's. maybe because i put the tps in wrong?</TD></TR></TABLE>
oh man that sucks. before you attempt to mess with your tps you should try adjusting your idle screw.
Koofy23
May 11, 2015 05:14 PM
slowLSTek
16
Mar 29, 2012 10:40 PM
Markis.
May 30, 2009 06:08 PM
DA-VISION-763
Sep 1, 2008 03:58 PM
CSHornet60
Jan 25, 2007 05:54 PM
