Is this normal?
Old Aug 16, 2006 | 12:18 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default Is this normal?
When i'm driving in any gear and then slap it in neutral, my rpm goes back to 1000 rpm then bounces up to 1200 then comes back down to 1000 and its not until i'm at full stop will my idle drop to 800 and is dead still.
Old Aug 16, 2006 | 10:21 PM
candy eg's Avatar
Default Re: Is this normal? (candy eg)
bump
Old Aug 17, 2006 | 03:30 AM
Enzo Speed's Avatar
The ECU has a different idle preset for when the car is moving. If the car is rolling at all, the ECU will pick up the VSS signal and it will adjust for the "rolling idle" preset. When you come to a complete stop and the VSS no longer detects movement, the ECU will switch to the regular idle. The rolling idle is supposed to be higher than the regular idle. It's not supposed to bounce around though...
Old Aug 17, 2006 | 08:36 AM
candy eg's Avatar
Default Re: Is this normal? (Enzo Speed)
it doesn't really "bounce" around it just goes up to 1200 then come back 1000.
Old Aug 17, 2006 | 02:22 PM
Enzo Speed's Avatar
Sounds normal
derilict
Apr 4, 2007 01:31 PM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
flood
Mar 30, 2005 08:46 AM
