speedo going haywire
Old Aug 16, 2006 | 10:58 AM
Tad's Avatar
Tad
Default speedo going haywire
hi, i've got a prob with speedo in my 92 cx eg.
basically it bounces around irratically.
sometimes i'll accellerate and it will just get stuck, then it'll "catch up" with my actual speed later on, or even get stuck showing like 190mph and then will try to do a full 360.
Just all in all crazy stuff,
but the odometer and trip counters seem to function fine, at least I haven't noticed anything.
any advice?
At first I thought it was the VSS, but now that I see that the odo works ok, i'm not so sure.
Old Aug 16, 2006 | 11:34 AM
sol2hatch's Avatar
Default Re: speedo going haywire (Tad)
your cluster may be bad. I had this problem, and changed the VSS, and it turned out to be the cluster. If you have a spare cluster or a friend that can let you use theirs to test it, then do that
Old Aug 16, 2006 | 03:23 PM
Tad's Avatar
Tad
gotcha
yeah it's old, some of the lights are out on it 'n stuff.
i wonder if I get preserve the mileage though..
Old Aug 16, 2006 | 08:13 PM
sol2hatch's Avatar
Default Re: (Tad)
if you get another cluster, you can either roll back the miles on it, or swap the part where the mileage is
Old Aug 16, 2006 | 08:22 PM
slowturbocx's Avatar
Default Re: (Tad)
my speedo went crazy worked like a tach, it ended up being a loose ground. on the body. check all the grounds in the engine bay.
malx
Sep 17, 2017 05:50 PM
kyorishin
Mar 1, 2008 07:01 PM
nomoreavril
10
Dec 11, 2006 04:02 PM
gakkuken
18
Nov 3, 2005 03:50 PM
mc
Apr 19, 2004 07:58 PM
