Rotating clicking noise when braking.. Any ideas??
Old Aug 16, 2006 | 08:26 AM
00ekcoupe's Avatar
Default Rotating clicking noise when braking.. Any ideas??
As the title states.. when braking I can hear a lite clicking noise (has to do w/ something rotating). Any ideas?
Old Aug 16, 2006 | 08:36 AM
TGO-MD's Avatar
Default Re: Rotating clicking noise when braking.. Any ideas?? (00ekcoupe)
It could be a ball joint, wheel bearing, or some debris in the brake caliper.
Raise the car on the side that is in question. Check the for play on the tire. Grab the tire from the 12 o'clock postion and 6 o'clock position and try to move it. If it moves, you need a new wheel bearing.
If it doesn't move, check the caliper area. This means you'll have to remove the wheel and inspect the caliper.
As for ball joints, not really sure how to diagnose them for damage.
m-
Old Aug 16, 2006 | 09:00 AM
Sleepy_Red_hatch's Avatar
Default Re: Rotating clicking noise when braking.. Any ideas?? (TGO-MD)
how much life left on the brake pads? i had this and it was the squeeler not on fully, the rotor must have been warped a little and it just touched on one spot on the rotor.
Old Aug 16, 2006 | 10:16 AM
00ekcoupe's Avatar
Thanks TGO.. I'll give those a shot.
Not exactly sure but it sounds like its coming from the inner cv joint area. Any more ideas?
Old Aug 16, 2006 | 10:47 AM
TGO-MD's Avatar
Is your car swapped? If so, you can swap the axles to see if the sound follows the axle. It could very well be a CV joint. I would imagine that the sound would intensify while you are turning in a particular direction.
m-
Old Aug 16, 2006 | 10:48 AM
strictly.business's Avatar
Banned
i had the same problem, it would shake really bad at higher speeds and click when i slowed down. thought it was a wheel bearing, took it apart and bearing felt fine, ended up being a cv joint on a 500 mile old axle.
Old Aug 16, 2006 | 11:02 AM
00ekcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TGO-MD &raquo;</TD></TR><TR><TD CLASS="quote">Is your car swapped? If so, you can swap the axles to see if the sound follows the axle. It could very well be a CV joint. I would imagine that the sound would intensify while you are turning in a particular direction.
m-</TD></TR></TABLE>
The car is not swapped. It doesn't make the noise when turning, only right when coming to a stop. Also when I turn the steering wheel left just til the wheel is sideways I hear a knock that sounds like its coming from above the driver side wheel. WTF is wrong w/ my car? This sucks ***!
I might just take my car to Honda to get an alignment and hopefully they'll check everything.
Old Aug 16, 2006 | 12:27 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Rotating clicking noise when braking.. Any ideas?? (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem, it would shake really bad at higher speeds and click when i slowed down. thought it was a wheel bearing, took it apart and bearing felt fine, ended up being a cv joint on a 500 mile old axle.</TD></TR></TABLE>
Same thing happened to my friends car but when we put in a new axle it still clicked occasionally. Still haven't figured it out.
90ED6LSV
Aug 29, 2019 08:14 PM
Tigereye225
Honda Civic (2001 - 2005)
May 15, 2016 03:59 PM
avio
Apr 16, 2010 12:51 AM
B18C-EG
Apr 17, 2008 06:37 PM
jtchinoy
15
Jan 23, 2007 01:00 PM
