have i forgoten anything and what power do you think i could make
99 civic si b16a2 stock internals
my setup
FMIC 2.5" piping
t3t4 50 compressor 63 exhaust
equal length manifold
3" downpipe (but only 2.25" exhaust at the moment)
35mm wastegate
fuel pump
fuel pressure regulator
magnecor leads
nkg plugs
greddy e manage
oil lines etc
on the look out for 440 injectors (would skyline gtr ones work)
the car had a custom turbo conversion using a t25 and ive changed a lot of the parts cause i wasnt happy, the e manage still has the map for the old setup once its all put together how safe would it be to drive on that map while awaiting a re map
and what sort of power do you think i could make and what sort of psi would you recomend me running
thanks
my setup
FMIC 2.5" piping
35mm wastegate
fuel pump
magnecor leads
nkg plugs
greddy e manage
oil lines etc
thanks
one thing i would do is make sure that your setup can make more power than you're going to make now....you will want to upgrade and when you do, you wont have to replace everything. It will be more $$ right now, but save your *** in the long run...trust me
also what are you using for a clutch??
If you change injectors dont expect that old setup's map to run. expecially if you're running larger injectors. 440cc injectors should support up to 300hp, may want to go a little larger though, just my .02 cents. Good luck.
pushinlsteg
May 27, 2005 12:06 AM
