have i forgoten anything and what power do you think i could make
Old 08-16-2006, 04:51 AM
dazcivic's Avatar
Default have i forgoten anything and what power do you think i could make
99 civic si b16a2 stock internals
my setup
FMIC 2.5" piping
t3t4 50 compressor 63 exhaust
equal length manifold
3" downpipe (but only 2.25" exhaust at the moment)
35mm wastegate
fuel pump
fuel pressure regulator
magnecor leads
nkg plugs
greddy e manage
oil lines etc
on the look out for 440 injectors (would skyline gtr ones work)
the car had a custom turbo conversion using a t25 and ive changed a lot of the parts cause i wasnt happy, the e manage still has the map for the old setup once its all put together how safe would it be to drive on that map while awaiting a re map
and what sort of power do you think i could make and what sort of psi would you recomend me running
thanks
Old 08-16-2006, 04:05 PM
dazcivic's Avatar
anybody
Old 08-16-2006, 05:40 PM
EK FLY's Avatar
Default Re: (dazcivic)
no more than 280 at the wheels if u get lucky meaby 300
Old 08-17-2006, 02:27 AM
dazcivic's Avatar
thats great i was even expecting that
what do you think about what i said about the map thas on the e manage
Old 08-17-2006, 12:28 PM
dazcivic's Avatar
oh and will skyline gtr injectors be ok
Old 08-17-2006, 02:26 PM
Man U FTW
Schister66's Avatar
still need a bov, couplers and clamps, and other misc fittings....other than that it looks good
i think 10 psi you might make 240-250whp....
Old 08-17-2006, 03:00 PM
dazcivic's Avatar
Default Re: (Schister66)
ooops forgot to mention bov but i have got one and couplers and clamps
thanks for input
Old 08-17-2006, 03:12 PM
Man U FTW
Schister66's Avatar
one thing i would do is make sure that your setup can make more power than you're going to make now....you will want to upgrade and when you do, you wont have to replace everything. It will be more $$ right now, but save your *** in the long run...trust me
also what are you using for a clutch??
Old 08-17-2006, 04:22 PM
dazcivic's Avatar
ive got an ACT 4 puck clutch cant remember what pressure plate but its the middle of the three they do, extreme is it
Old 08-17-2006, 05:28 PM
Man U FTW
Schister66's Avatar
sweet, well it looks like your set then...good luck
Old 08-18-2006, 06:20 AM
dazcivic's Avatar
what about the injectors ive mentioned
and the would it be safe to run on the old map till its remapped
Old 08-19-2006, 10:11 AM
dazcivic's Avatar
anyone
Old 08-20-2006, 02:59 PM
dazcivic's Avatar
bump
Old 08-20-2006, 04:45 PM
JoePSI's Avatar
If you change injectors dont expect that old setup's map to run. expecially if you're running larger injectors. 440cc injectors should support up to 300hp, may want to go a little larger though, just my .02 cents. Good luck.
EFjoe91
10-06-2012 11:28 AM
BMo Tuning
09-05-2007 12:56 PM
Jax419
06-14-2007 01:32 PM
pushinlsteg
05-27-2005 12:06 AM
Quick Reply: have i forgoten anything and what power do you think i could make
