Automatic to Manual conversation
Old Aug 16, 2006 | 01:02 AM
srg's Avatar
srg
Default Automatic to Manual conversation
Hello,
Is it possible to swap manual transmission in to 92 civic with d16? What do I need to do that swap?
Old Aug 16, 2006 | 01:33 AM
Miracle's Avatar
Default Re: Automatic to Manual conversation (srg)
Things you will need:
Clutch
Clutch pedal
Tansmission
ECU
Shifter and linkages with hardware
Flywheel
Manual transmission engine bay mount.
Axles
I think I got everything....
Old Aug 16, 2006 | 04:35 AM
fventura03's Avatar
CHECK THE FAQ ABOVE.
Old Aug 16, 2006 | 07:34 AM
vestalfootball72
Guest
Posts: n/a
You are going to have to have the hydro lines for the clutch, along with the manual throttle cable if you swap all the pedals. Also your tranny mount will need to be moved back a little bit or you will have to buy the kit from hasport-
Old Aug 16, 2006 | 07:40 AM
TorquelessB16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srg &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
Is it possible to swap manual transmission in to 92 civic with d16? What do I need to do that swap?</TD></TR></TABLE>
Personally, I'd just buy a manual car and save myself the trouble and money of a tranny swap. I haven't done it, but from what I read in the write up, it seems like a bitch.
Old Aug 16, 2006 | 07:48 AM
Syndacate's Avatar
Default Re: Automatic to Manual conversation (ZeeSix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeeSix &raquo;</TD></TR><TR><TD CLASS="quote">
Personally, I'd just buy a manual car and save myself the trouble and money of a tranny swap. I haven't done it, but from what I read in the write up, it seems like a bitch. </TD></TR></TABLE>
Not at all, it's very easy, maybe harder than it looks - one day and having never done it before you can definately do it. (assuming you have all the parts)
Old Aug 16, 2006 | 08:03 AM
philosofy1's Avatar
Default Re: Automatic to Manual conversation (vestalfootball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Things you will need:
Clutch
Clutch pedal
Tansmission
ECU
Flywheel
Axles
I think I got everything....</TD></TR></TABLE>
M/C, as well as the hydro lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">You are going to have to have the hydro lines for the clutch, along with the manual throttle cable if you swap all the pedals. Also your tranny mount will need to be moved back a little bit or you will have to buy the kit from hasport- </TD></TR></TABLE>
you can still use the throttle cable.
believe it or not, where i live civics are outrageously priced. but the autos are cheaper than the manuals, so what i did was saved about $1500 on my civic and did a conversion. not only is it easy as hell, but i saved some money.
Old Aug 16, 2006 | 08:36 AM
vestalfootball72
Guest
Posts: n/a
Default Re: Automatic to Manual conversation (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
believe it or not, where i live civics are outrageously priced. but the autos are cheaper than the manuals, so what i did was saved about $1500 on my civic and did a conversion. not only is it easy as hell, but i saved some money.</TD></TR></TABLE>
From my experience you need to swap out the throttle cable if you go to a manual pedal set- if you dont the pedals are all too close
Old Aug 16, 2006 | 09:36 AM
srg's Avatar
srg
One guy is selling me his 1992 civic with D16z6 for $2000 I think it's a good deal.. What do you think?
Old Aug 16, 2006 | 10:37 AM
byronl's Avatar
Default Re: (srg)
i did my tranny conversion for about $600-$800. It's not hard to the conversion, it just takes up alot of time to complete it.
unxpected323
Transmission & Drivetrain
Sep 13, 2008 11:11 AM
Mandark06
Feb 24, 2007 08:28 PM
Toolman
May 17, 2005 08:18 AM
wannab20hatch
Aug 21, 2002 07:03 PM
LS Teg
Mar 21, 2002 02:47 PM
