whats the highest turbo y7 hP on honda tech..?
ok i have a build up im waitiing on my apointment to get tuned and i want to know what kind of hp numbers i am looking at making heres the list.. also what kind of timing should i have at peak.. at a high boost pressure i plan on maxing out the turbo or injectors.. im building a z6 head right now but till its done im gonna tune it on the y7
y8 block
y7 head stock cleaned and pressure tested new seals
srp 75.5 9:1
eagle rods
oem bearings
z6 crank
ARP head studs
felpro head gasket
aem fuel rail
255plh walbro in tank
t3/t4e 57 trim
large frontmount ic
types s bov
3 inch downpipe
open wastegate vented out the fender
750cc RC injectors
35mm tial 8 psi spring
profec b2 boost controller.. still cant get it to hold boost right..????
stock y7 tranny
stock flywheel
exedy stage 2 clutch.. i think its the 3 puck 400 whp rated
street tuned crome pro at 10 psi spikes to 14psi in first gear.. wtf but only 9psi in 3rd
Lc-1 wideband
Modified by hitatree.at125mph at 9:54 PM 8/15/2006
y8 block
srp 75.5 9:1
eagle rods
oem bearings
z6 crank
ARP head studs
felpro head gasket
aem fuel rail
t3/t4e 57 trim
large frontmount ic
types s bov
3 inch downpipe
750cc RC injectors
stock y7 tranny
stock flywheel
Lc-1 wideband
THEDirtyDseriesWOOT
Jan 6, 2007 01:20 AM
