pump brakes and motor revs up?
Old Aug 15, 2006 | 07:40 PM
JLefevers's Avatar
Default pump brakes and motor revs up?
like it says what would cause this and i am not talking like a lil rev it revs fromm like 700 to almost 1700 rpm? juss sitting still pumping the brakes
Old Aug 15, 2006 | 08:37 PM
SIred91's Avatar
Rainman
Default Re: pump brakes and motor revs up? (JLefevers)
the vacuum your brake booster uses comes from where?
THE MOTOR. Or more specificaly, the intake manifold. check all your vacuum lines, and your brake booster.
Old Aug 15, 2006 | 09:25 PM
salman's Avatar
Default Re: pump brakes and motor revs up? (SIred91)
Check there is a Oneway Valve,
Old Aug 15, 2006 | 09:29 PM
jdmazm's Avatar
Default Re: pump brakes and motor revs up? (salman)
check your brake booster hose, drivers side on the firewall. Its a fat hose that connects into another fat hose its a fat bitch hoe.
Old Aug 15, 2006 | 09:30 PM
salman's Avatar
ur break booster is weak,
jdmazm's Avatar
Default Re: pump brakes and motor revs up? (jdmazm)
jakscivic pic i think, if you want it down I'll do it per request. All the way to the right above the master cylinder.
Old Aug 16, 2006 | 03:22 AM
SETI20's Avatar
That's a nice setup. Lota room for cleaning it up...but I like the idea.
That way you can weld the manifold up and make it look purrty.
Old Aug 16, 2006 | 04:07 AM
ludesrv's Avatar
I've always been able to do that in all my car. Even my dad old 2002 civic I was able to do that, even my moms 2005 Kia. Sure, the newer it was, it never went that high, but I could get my dads old civic to 1200rpm by doing that, always thought it was normal?
Old Aug 16, 2006 | 05:23 AM
HT Chaplain's Avatar
Loved
Default Re: (ludesrv)
mine does the same, i dont thinks it goes that high but i never tried?
cityofcaterpillars
Jun 12, 2010 02:15 AM
Eighty-Nyne
12
Apr 28, 2009 07:59 PM
'95hatchCivic
Feb 20, 2009 11:56 AM
jikespingleton
Jan 2, 2007 01:31 AM
Civd16y8
12
Aug 18, 2005 03:00 PM
