problems with b18b swap
Old Aug 15, 2006 | 07:29 PM
error's Avatar
Default problems with b18b swap
im using the stock engine harness that was modified for my b20vtec swap. everything is pretty much plugged in and ready too go. when i go to crank the motor over, the starter engages but the motor will not fire up. i have a 96 cx hatch with 98 ls motor.... any one have suggestions? common problems, anything please. feel free to ask for more input if necessary
Old Aug 15, 2006 | 07:36 PM
aholeb18's Avatar
Default Re: problems with b18b swap (error)
which is it, b20vtec or an ls? vtec or non vtec?
Old Aug 15, 2006 | 07:37 PM
error's Avatar
Default Re: problems with b18b swap (aholeb18)
im trying get the ls motor too work... ls.
Old Aug 15, 2006 | 07:43 PM
aholeb18's Avatar
i have the same swap. do you have everything plugged in? there aren't that many wiring mods for this swap. do you have anything cross plugged? that fucked me up.
Old Aug 15, 2006 | 07:44 PM
aholeb18's Avatar
searching helped me a ton. i found everything i needed on HT.
Old Aug 15, 2006 | 07:45 PM
error's Avatar
everything seems legit. but im sure ive overlooked something..... does the secondary 02 sensor need to be plugged in? i only have the one in the exhaust mani plugged.
Old Aug 15, 2006 | 07:46 PM
error's Avatar
yeah i usually have time to search but i have a virus on my comp. at home so im using a friends
Old Aug 15, 2006 | 07:54 PM
error's Avatar
what fuel preassure should i be running?
Old Aug 15, 2006 | 08:04 PM
aholeb18's Avatar
shouldn't matter. for a stock set up, just plug and play. sensor 2 won't have anything to do with it starting, sorry. you did the crank position sensor, and the iacv fix right?
Old Aug 15, 2006 | 08:07 PM
error's Avatar
no, didnt do that. please elaborate
Old Aug 15, 2006 | 08:10 PM
error's Avatar
only thing i have done was temporarily blocked coolant lines too and from the throttle body, and replaced the tps sensor.
Old Aug 15, 2006 | 08:12 PM
error's Avatar
tps sensors are universal for b series right
Old Aug 15, 2006 | 08:13 PM
aholeb18's Avatar
seach for katman. sorry but i can't remember exactly, and i don't want to mislead you. katman's info totally helped me out!
Old Aug 15, 2006 | 08:14 PM
error's Avatar
Old Aug 15, 2006 | 08:17 PM
aholeb18's Avatar
let me know if you found what you needed. i know there isn't a lot to it. wish i could have helped more.
Old Aug 17, 2006 | 10:48 AM
error's Avatar
Default Re: (Zach_06)
timming is fine. thought since i was using the usdm b18b i wouldnt have any issues and it would be plug and play. this thing cranks but wont start. i will go over AGIN a few things and see whats up.
Old Aug 17, 2006 | 04:59 PM
error's Avatar
Default Re: (error)
rather than testing the voltage of the injectors, can i just take off the fuel rail and pull the injectors out and see if they are squirting? will i have any sealing problems when i put them back in?
Old Aug 17, 2006 | 05:40 PM
error's Avatar
Default Re: (error)
OMG LOOSE GROUND WIRE@#$%@!$# starts right up now. only the idle is way up there in the 4000's. maybe because i put the tps in wrong?
Old Aug 17, 2006 | 05:50 PM
unknown0001's Avatar
Default Re: (error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">OMG LOOSE GROUND WIRE@#$%@!$# starts right up now. </TD></TR></TABLE>
lol I was just going to point that out, which ground was it? the transmission thick ground?
Old Aug 17, 2006 | 06:25 PM
error's Avatar
Default Re: (Mr.RHTuner)
it was the ground to the head. it was skrewed in but just not tightend. now im throwing code 7 and 54
eweimert
12
Jan 29, 2008 08:18 PM
yeaaaa its slow
Apr 9, 2003 06:40 PM
vtecsiqt
Jan 20, 2002 10:10 PM
