I HAVE A WEIRD NOISE THAT GOES AWAY WHEN CLUTCH PEDAL PRESSED TO FLOOR.
Old Aug 15, 2006 | 07:07 PM
tvrsir's Avatar
Default I HAVE A WEIRD NOISE THAT GOES AWAY WHEN CLUTCH PEDAL PRESSED TO FLOOR.
i have this noise that sounds like a freaking helicopter when it idles, it'a a 1997 lx 5 speed civic, but when i step on the clutch pedal all the way down it goes away. it would not go away half way down, only when the tranny is fully disenegaged from the engine it stops making noise.
i think i can rule out a throw out bearing,
can it be a pilot or like the mainshaft bearing in the tranny in the front?
Old Aug 16, 2006 | 05:41 AM
ITR-2001's Avatar
Default Re: I HAVE A WEIRD NOISE THAT GOES AWAY WHEN CLUTCH PEDAL PRESSED TO FLOOR. (tvrsir)
Sound like what might of happen to mine..The bolt holding the flywheel might of came lose
Old Aug 16, 2006 | 12:10 PM
spoonek9's Avatar
It's most likely your mainshaft bearings going out.
Old Aug 16, 2006 | 03:03 PM
Enzo Speed's Avatar
Default Re: I HAVE A WEIRD NOISE THAT GOES AWAY WHEN CLUTCH PEDAL PRESSED TO FLOOR. (spoonek9)
Yep, it's the input shaft bearing. Have fun fixing that
Old Aug 17, 2006 | 06:46 AM
myst's Avatar
Default Re: I HAVE A WEIRD NOISE THAT GOES AWAY WHEN CLUTCH PEDAL PRESSED TO FLOOR. (Enzo Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed &raquo;</TD></TR><TR><TD CLASS="quote">Yep, it's the input shaft bearing. Have fun fixing that </TD></TR></TABLE>
H22_CB7_JAY
17
Feb 15, 2013 06:48 PM
Vt3c_eg
Apr 28, 2008 11:31 AM
uNF$@#!
May 13, 2005 07:59 AM
SJR
Apr 21, 2005 06:56 PM
B18B EK
Feb 20, 2004 07:19 PM
