d16z6 to d15b vtec swap??
Old Aug 15, 2006 | 06:59 PM
ci_v_ic's Avatar
Default d16z6 to d15b vtec swap??
ok ive got a 93 del sol si with the original z6 it threw a rod through the block so im buying the jdm d15b vtec. just wanting to make sure that all the sensors hook up all the same and all taht good ****. thanks in advance.
Old Aug 15, 2006 | 07:08 PM
gold_ef's Avatar
everything except the egt which you dont need if you run the p08 ecu then you dont even get any codes
Old Aug 15, 2006 | 07:13 PM
ci_v_ic's Avatar
Default Re: (gold_ef)
i believe i have the p28?? correct. idk lol it may be the p08
Old Aug 15, 2006 | 07:16 PM
gold_ef's Avatar
p28 is in your car but the swap should come with the p08
Old Aug 15, 2006 | 07:58 PM
byronl's Avatar
Default Re: d16z6 to d15b vtec swap?? (ci_v_ic)
if you live in cali, use the p28 ecu with the jdm d15b
Old Aug 15, 2006 | 08:44 PM
Shao Lin Wu Su's Avatar
Default Re: d16z6 to d15b vtec swap?? (byronl)
And the Hondata S300...
My old CRX with nothing but I\H\E and Crower cams, and the Hondata S300:
Old Aug 15, 2006 | 09:11 PM
ci_v_ic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold_ef &raquo;</TD></TR><TR><TD CLASS="quote">everything except the egt which you dont need if you run the p08 ecu then you dont even get any codes</TD></TR></TABLE>
egt?? exhuast gas temperature??
so i will get that code if i run a p28?? if i get that code will it make the car run shitty??
Old Aug 15, 2006 | 10:33 PM
Max Kling's Avatar
Use the P28 for now, it will run it just fine.
Then later on you can chip the p28 and just run P08 maps on it.
Its no big deal, the engine will pretty much bolt and plug right up.
Old Aug 16, 2006 | 01:21 AM
slywfbpsi's Avatar
Default Re: d16z6 to d15b vtec swap?? (Shao Lin Wu Su)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shao Lin Wu Su &raquo;</TD></TR><TR><TD CLASS="quote">And the Hondata S300...
Sweet! that's more than my 00si had with an I/E and cam gears
Old Aug 16, 2006 | 01:29 AM
graveltravel2's Avatar
never underestimate the single slammerrrr!!!!
Old Aug 16, 2006 | 03:15 PM
gold_ef's Avatar
i mean egr
Old Aug 16, 2006 | 06:39 PM
rat_racer's Avatar
I just did the same swap on my 95. JDM cars do not have a charcoal evap recovery cannister but the USDM models do. There is a vacuum actuates solenoid that is mounted on the rear of the intake manifold on your USDM model that you will need to find a place for and tap another vac line for. The other option would be to re-use your USDM manifold. Otherwise I had no other trouble using the JDM sensors with my USDM ECU.
Be sure to check for broken sensors on you new motor before you go to install it. Also, check the crank pulley to make sure it matches your accessories. chances are you will have to re-use your crank pulley too. My A/C compressor was different than the one that came with my new motor, so I had to use my old crank pulley.
Good luck
Old Aug 16, 2006 | 08:01 PM
ci_v_ic's Avatar
Default Re: d16z6 to d15b vtec swap?? (rat_racer)
cool man thanks. the engine im getting comes with all accessories on it. ac, ps, and alternator are already on there. ill just have to figure out that charcoal canister ****
probably just reuse my usdm mani. thanks for all the info i really appreciate it. you guys rock
Old Aug 16, 2006 | 10:04 PM
Default Re: d16z6 to d15b vtec swap?? (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">
Sweet! that's more than my 00si had with an I/E and cam gears</TD></TR></TABLE>
You are telling me, that is a little more than my stock 2005 Si made
Old Aug 17, 2006 | 12:14 AM
broketuner-Sol_Si's Avatar
wow, that's only 17whp less (and about the same tq) than my previous b16a setup tuned on crome had with I/H/E/IM/TB. Glad I'm running a z6 now...planning on boosting it
Old Aug 17, 2006 | 03:28 AM
slywfbpsi's Avatar
You are telling me, that is a little more than my stock 2005 Si made </TD></TR></TABLE>Yeah, I'm glad I have a d15b in a 91 hatch now.
riceordie
15
Sep 20, 2011 10:19 AM
'90 honda crx
24
Sep 12, 2006 09:34 PM
rockthegens
Aug 23, 2005 08:11 AM
steve0unce
10
Nov 26, 2004 06:51 PM
Erod
Apr 20, 2004 12:38 PM
