quick question...please help
Old Aug 15, 2006 | 05:58 PM
NeRdY's Avatar
Default quick question...please help
im running a 00 GSR in a 96 civic, some ******** broke into my car and took my radio and my ECU, my buddy has a 97 GSR ECU P72, that he said hes give me, till i save up for a chipped 28 again, would that be no problem to use? i want no check engine lights, nothing?.. please help cuz i need to pass insoection also
Old Aug 16, 2006 | 09:39 AM
slowcivic2k's Avatar
Default Re: quick question...please help (NeRdY)
shouldnt be a problem, im not sure if the gsr has a crank flux sensor, or the purge solenoid, but if you dont use the purge sensor, you should be fine, leavingthe line hooked up without a sircuit to complete it will cause a surging idle, becuase it will suck air from the gas tank, since the valve doesnt close anymore, butit shouldbe fine.
Old Aug 16, 2006 | 11:06 AM
CH2iS*'s Avatar
i don't see why you would have a problem using that ecu. good to go
Old Aug 16, 2006 | 11:26 AM
LowSlow93Sol's Avatar
Default Re: quick question...please help (CH2iS*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CH2iS* &raquo;</TD></TR><TR><TD CLASS="quote">i don't see why you would have a problem using that ecu. good to go </TD></TR></TABLE>
x2 gsr motor + gsr ecu = normal
Ruben19
Engine Management and Tuning
Sep 1, 2011 11:08 AM
Greenb16
Sep 3, 2006 09:53 PM
whtcrx
Oct 20, 2005 09:09 PM
1320DRAGWORKX
Jul 28, 2004 08:20 PM
PolySquared
Nov 29, 2003 06:09 PM
