a little turbo
Old Aug 15, 2006 | 02:47 PM
hatch96y7's Avatar
Default a little turbo
i was at work today and seen a turbo from one of our trucks and was wondering if it would be good to slap on my civic for a little fun it comes from a bobtail volvo the name on it is called a holster can someone give me an opinion or answer
Old Aug 15, 2006 | 03:04 PM
littleredcivic's Avatar
No. If you want some cheap fun, get a turbo from a WRX. It is a small TD04 and is always available for very little money. The only thing with this turbo is that it is water and oil cooled, so it requires a bit more plumbing to make it work. But, you can usually find one almost brand new for about 300 bux.
Old Aug 15, 2006 | 04:33 PM
Boosted193's Avatar
yeah either that or search Garret T25, its not too expensive at all but reliable too. It doesnt lag to start spooling, It comes stock in the Mazdaspeed Protege, and Garret is reputable. Subaru has some nice parts, WRX are niiiiiiiiiiiiiiiice under the hood.....Even try Saab lol But you might experience some lag time with the truck turbo
Old Aug 15, 2006 | 05:46 PM
mercfwd2's Avatar
Default Re: a little turbo (hatch96y7)
Plus i've been told and correctme if i'm wrong but that one may be a deisel? and if so it takes longer to spool, much like semi turbos
Old Aug 15, 2006 | 07:54 PM
hatch96y7's Avatar
Default Re: a little turbo (mercfwd2)
but how much longer would it not be worth a free big *** turbo i mean im sure the lag must be in the trucks computer to smothen out the torque curve i dont think theyre going for raw power
Old Aug 15, 2006 | 07:59 PM
Miracle's Avatar
BIG turbo on a small motor = not being able to produce much, if ANY boost.
Small turbo = possible over rotating the turbine blades and f'n something up.
You need to check and see what turbos have worked with your engine before slapping one on there for kicks.
It takes alot of research to size a turbo. So make sure if you are going to do it, that it is done right.
Old Aug 15, 2006 | 08:10 PM
hatch96y7's Avatar
Default Re: a little turbo (Red_EM2)
so even if i boost low i wouldnt be able to make say 50 to 75 horse power on my d16y7
Old Aug 15, 2006 | 08:13 PM
HiProfile's Avatar
Was it HOLSET by any chance? Take a measurement of the wheels, a usable (medium sized) honda turbo would be around 2" for intake & exhaust wheels. That doesn't tell the whole story, but it gives you an idea.
Old Aug 15, 2006 | 08:34 PM
hatch96y7's Avatar
Default Re: a little turbo (HiProfile)
alrite there are numbers and **** on the turbo tommorow i will take meusurments of everythin both exhaust and intake and also what typr of managment and stuff will i need or can i just runnit like that with all custom piping because i have a torch welder and allot of aluminum iping laying around
Old Aug 15, 2006 | 08:45 PM
Syndacate's Avatar
A smaller turbo would be better for the app you just listed. Off of a Talon or GSX/GS-T Eclipse. Saab turbo would work as well, I'd stick with those sorts though.
Old Aug 16, 2006 | 03:16 PM
hatch96y7's Avatar
Default Re: (aallbbeerrtttttt)
i looked at the turbo and it is a holset and the intake wheel is 2 inches wide and the exahust is 2 and a half wide so can i use it i asked and they told me its okay to take it
Old Aug 18, 2006 | 08:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">
wrx stock turboes are made by IHI, mitsubishi, volvo, and saab turbos are td04's, then you got your 14g, 15g, or 16g</TD></TR></TABLE>
the STI uses an IHI VF39, but the WRX has a little ******** TD04-13T or something like that.
elrandeeto
15
Jun 22, 2005 08:03 PM
Jasz
Mar 7, 2005 05:50 AM
crxvtecturbo
Dec 5, 2004 04:12 PM
GSRacer
Jan 2, 2002 06:20 AM
wu tang
Dec 29, 2001 04:17 PM
