Can't get my car to start
Old Aug 15, 2006 | 02:18 PM
cobrajoe99's Avatar
Default Can't get my car to start
I just put a jdm d15b7 into my 94 civic dx, it is the same type engine I took out. when I try to start the engine, it will turn over but not start. the engine is getting gas and the spark plugs are firring. any one have any ideas of what I need to do to get the engine to start?
Old Aug 15, 2006 | 03:05 PM
littleredcivic's Avatar
is everything plugged in? are the injectors firing? how do you know the engine is getting gas? are the spark plugs firing at the right time? compression check??
Old Aug 15, 2006 | 03:08 PM
Slopoke's Avatar
Default Re: Can't get my car to start (cobrajoe99)
Check the firing order of the spark plug wires.
Then check cam timing,
Then compression.
That is if you are SURE your getting fuel and spark.
Old Aug 16, 2006 | 01:55 PM
cobrajoe99's Avatar
Default Re: Can't get my car to start (Slopoke)
Everything is plugged in. the engine was supposed to be compression checked before I bought it. the spark plugs are in the right order. gas is coming out of the injectors.
I'm assuming the timing was right, when the engine was shipped to me. I guess I need to check to make sure the compression and timing are correct.
Old Aug 16, 2006 | 02:27 PM
black-92si's Avatar
try push starting it, maybe your starter is bad
jspecwhore
43
May 11, 2015 07:40 PM
Hondaguy83
Dec 5, 2012 05:21 PM
gowenburnett
May 30, 2011 05:20 PM
nic0h
Jun 23, 2010 07:51 PM
g2turbo
Sep 17, 2003 08:31 PM
