Could bad axles cause the check engine light to come on??
Old Aug 15, 2006 | 12:22 PM
EnKidu's Avatar
Default Could bad axles cause the check engine light to come on??
I have needed to change mine for a long time, and now I hear the sqeak and clunck around turns, just went for a smog yesterday and not the lights on. I was hoping the old guy who checked it did not pull a wire or something.
Car runs fine though. If you guys think the axle cant activate it I'lll find a local mech to pull codes and tell me,
Thanks
Old Aug 15, 2006 | 12:23 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Could bad axles cause the check engine light to come on?? (EnKidu)
I'm pretty sure it won't come on.
Go to autozone to pull the code. Its free
Old Aug 15, 2006 | 12:25 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnKidu &raquo;</TD></TR><TR><TD CLASS="quote">I have needed to change mine for a long time, and now I hear the sqeak and clunck around turns, just went for a smog yesterday and not the lights on. I was hoping the old guy who checked it did not pull a wire or something.
Thanks</TD></TR></TABLE>
no a bad axle cannot give a CEL. but if you have ABS it might activate the sensor.
Old Aug 15, 2006 | 12:29 PM
EnKidu's Avatar
Thank you so much guys, so if I have abs ( which I do ) then a bad axle could activate the cell, right?
gmapping nearest autozone now...
Old Aug 15, 2006 | 12:32 PM
philosofy1's Avatar
Default Re: (EnKidu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnKidu &raquo;</TD></TR><TR><TD CLASS="quote">Thank you so much guys, so if I have abs ( which I do ) then a bad axle could activate the cell, right?
gmapping nearest autozone now...</TD></TR></TABLE>
not CEL, the ABS light (might).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure it won't come on.
Go to autozone to pull the code. Its free</TD></TR></TABLE>
but definately take it to autozone or any major part store, they'll check it for free.
well, as long as it's OBD2.
Old Aug 15, 2006 | 02:00 PM
NonovUrbizniz's Avatar
Loved
No.
Bad axels won't cause a cel light unless they snap off and take out some sensors under the hood.
jonyi27
Nov 23, 2012 07:47 PM
canadianSIR-G
Jan 31, 2007 10:14 AM
suken19
Jan 23, 2007 09:39 PM
whatsthatnoise
Oct 10, 2006 03:09 PM
blkgsr03
10
Apr 20, 2005 05:29 PM
