1991 Honda Civic Si
Directly bolts up: D series
Directly wired: D16A6, SOHC ZC, DOHC ZC, OBD0 LS engines (this ones a B series tho, you would need mounts and driveshafts, the rest is stock)
DOHC ZC is the most powerful one that will 'just drop it'. Match it to your stock Si tranny (short geared) use stock driveshafts, voila.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamblezhang »</TD></TR><TR><TD CLASS="quote">what do you think B16A 88-91 (SiR I) Motor JDM? dirct fit or not?</TD></TR></TABLE>
ahhh not even close to a DIRECT fit. Best bang for your buck and something that will just about drop in would be a ZC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamblezhang »</TD></TR><TR><TD CLASS="quote">thank you very much for all the info. with a dohc will beat my h22? hehe 0 to 60mph?</TD></TR></TABLE>
preludes are heavy pigs,,so the dohc zc civic will probably pull on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag »</TD></TR><TR><TD CLASS="quote">
preludes are heavy pigs,,so the dohc zc civic will probably pull on it </TD></TR></TABLE>
I ran my lude 14.8. Fastest DOHC ZC I've seen around my area was 15.4 on the 1/4.
Would put up a fight, but I think the ZC would lose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 »</TD></TR><TR><TD CLASS="quote">You live California, the DOHC ZC is not smog legal.</TD></TR></TABLE>
good point buddy,,this guy should just stick wit the d16a6 then..or maybe get an obd0 ls engine....are they legal over there?
As long as the motor doesn't come from a truck (CRV), has a USDM counterpart, and is the same year as the chassis or newer, you can swap the motor. So yeah, you can swap an B18 as long as you run the emissions correctly and the motor isn't older than your car. You also have to convert to whatever OBD the motor is.
So, you can't run a '91 B18 in a '92 Civic but you can run any '92+ B18. If you run a B16, you have to be set up like a '94-'95 Del Sol VTEC or '99-'00 Civic Si. And so on.
rice a roni
Apr 13, 2006 04:59 PM
h22_crx
13
Oct 18, 2005 08:40 AM
