Wheels and brakes
Does anyone run big brakes with 15" or 16" wheels? I would prefer 15's but I am wondering what your opinions or experience is with a larger caliper and rotor. I will be buying some new wheels, possibly stock blades and I am trying to see what my options are for my teg. TIA
Please post your offset, wheel size (diameter and width) pictures and brake kit setup. Thanks a lot
Someone should bring you to a gangbang, with you being the victim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAQ thread »</TD></TR><TR><TD CLASS="quote">
---Brakes---
https://honda-tech.com/zerothread?id=1205135 – Setup List
https://honda-tech.com/zerothread?id=1079051 – 96spec ITR on DA
https://honda-tech.com/zerothread?id=1024546 – NSX Brakes
https://honda-tech.com/zerothread?id=408117 – ITR Calipers
https://honda-tech.com/zerothread?id=475568 – General Upgrade Information
---Brakes---
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">Does anyone run big brakes with 15" or 16" wheels? I would prefer 15's but I am wondering what your opinions or experience is with a larger caliper and rotor. I will be buying some new wheels, possibly stock blades and I am trying to see what my options are for my teg. TIA
Generally most quality big brake kits call for a 17inch wheel minimum.
So just buy a nice rotor set and aftermarket calipers.
I've drove cars with Big brake kits. During hard braking you don't have as much pedal fade and keep a steady braking consistency.
15's and 16's...no I've not seen big brake kits that'll work with them. Thats just me though.
</TD></TR></TABLE>Generally most quality big brake kits call for a 17inch wheel minimum.
You are right. But spoon caliper means u can only use up to 11inch ITR discs, which are actually sufficent for track use, given u have upgraded other brake component as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogogomoveit »</TD></TR><TR><TD CLASS="quote">You are right. But spoon caliper means u can only use up to 11inch ITR discs, which are actually sufficent for track use, given u have upgraded other brake component as well.</TD></TR></TABLE>
Which offset is needed? And wheel width? The problem is, is that I intend on selling my 17" volks for something smaller.
trhoppe
May 6, 2004 01:52 PM
Mister Fixer
May 8, 2003 02:02 PM
