car shakes
Old Aug 15, 2006 | 04:34 AM
Hwj_33's Avatar
Default car shakes
Does any one have a clue why the car shakes when I accelerate and when I'm on the higway going about 60-70 mph. By the way I have a H22a4 SH swap in my accord. LMK..
Old Aug 15, 2006 | 06:49 AM
gianinline's Avatar
Maybe because you have your wheels out of aligment. It could be tires out of balance as well. These options are common to be felt in a certain mph range and such.
That is only one of the possible problems, since I figure that is what could be happening to your ride.
Old Aug 15, 2006 | 07:24 AM
Duane_in_Japan's Avatar
Default Re: (gianinline)
I would get it up on jackstands and shake the hell out of the inner CV Joints and see how one feels compared to the other.
Old Aug 15, 2006 | 02:04 PM
V6iCkSpEeD's Avatar
It could be tires need to be balanced, your axles, motor mounts, i would start with the wheels, if you feel it only when you accelerate is could be motor mounts and bad axles!
Old Aug 16, 2006 | 08:33 AM
B00ST2nR's Avatar
Default Re: (V6iCkSpEeD)
Like mentioned above, check your alignment, wheel balance, then axles.
Old Aug 17, 2006 | 09:35 PM
fishwgoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gianinline &raquo;</TD></TR><TR><TD CLASS="quote">Maybe because you have your wheels out of aligment. It could be tires out of balance as well. These options are common to be felt in a certain mph range and such.
That is only one of the possible problems, since I figure that is what could be happening to your ride.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V6iCkSpEeD &raquo;</TD></TR><TR><TD CLASS="quote">It could be tires need to be balanced, your axles, motor mounts, i would start with the wheels, if you feel it only when you accelerate is could be motor mounts and bad axles!</TD></TR></TABLE>
ditto!!!1 you can do it yourself or take it to a mechanic
vietboiracer0
Oct 27, 2005 12:14 PM
Tee Jay
10
Oct 11, 2005 07:35 AM
DeeCeeTwo
Jul 7, 2005 03:33 AM
Coltrane
Feb 22, 2005 08:22 PM
