Car Shaking!
Old 10-10-2005, 05:54 PM
Tee Jay's Avatar
Default Car Shaking!
First off its a 96' HB with a GS-R swap. I/H/E. When driving under 75mph the car drives normal but once I exceed that speed the car shakes a lot! I'm guessing it could be my tires needing a balance/alignment. Could it possibly a need of new axles? Its GS-R axels that came with the swap.
TIA!
Old 10-10-2005, 05:56 PM
riceburnerryan's Avatar
im guessing the wheels need to be aligned and balanced
Old 10-10-2005, 05:57 PM
Tee Jay's Avatar
Default Re: (riceburnerryan)
what is a way i can check my axles see if their bad or not?
Old 10-10-2005, 06:55 PM
enhancedCL9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">im guessing the wheels need to be aligned and balanced</TD></TR></TABLE>
Old 10-10-2005, 08:06 PM
.Ry
.Ry's Avatar
Default Re: (JDMeh3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green_Machine &raquo;</TD></TR><TR><TD CLASS="quote">what is a way i can check my axles see if their bad or not?</TD></TR></TABLE> Check for tears in the boots, if there are tears then you should replace them. If there are no tears, pull on the axle and if it moves exessively then I would think about them. Normally shaking at higher speeds is due to unbalanced tires. Alignments are normally pulling issues. Unless the tires are fubered up. Like cupping or feather.
Old 10-10-2005, 08:08 PM
mgags7's Avatar
the easiest way to know if you have bad axles is to go turn tight circles in an open parking lot with as much gas as you can, they will knock if theyre bad...and check the boots visually to see if theyre ripped...
you need an alignment....
Old 10-10-2005, 08:29 PM
AcidFr33ze's Avatar
Default Re: Car Shaking! (Green_Machine)
Can it be the bushings in the lower control arm or something? (just throwing iddeas on the table)
Old 10-10-2005, 08:54 PM
mgags7's Avatar
i doubt seriously that those bushings are bad enough to let the car shake, they would have to be almost non existent to let that arm shake enough to shake the shock with enough force for it to wiggle....
it could be bad ball joints, if they are bad, the car woud violently wiggle from side to side sometimes, and it could be more moderate at times....be careful of that, you can lose control easily....
Old 10-10-2005, 11:13 PM
Rhymesayer's Avatar
Default Re: (mgags7)
Check your rotors too.
Old 10-10-2005, 11:23 PM
mrehagencivic's Avatar
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote"> Unless the tires are fubered up. Like cupping or feather. </TD></TR></TABLE>
i am having the same problem right now, only over 75 does the car(94 civic coupe) shake or vibrate, i have been doing some research on this and in my situation it turns out its the tires, when rotors are warped the steering wheel vibrates the whole time your stopping which mine does not do, balance and aliangment didn't fix my problem either, and i know my axles are good. good luck with your problem and check/replace your tires
Old 10-11-2005, 07:35 AM
Tee Jay's Avatar
Default Re: (mrehagencivic)
thanks for all the comments. I'm going to get the tires balance/alignment soon and hopefully it'll be fixed.
1badteg
05-17-2007 08:06 PM
blakebrkr
12-15-2006 04:54 PM
Hwj_33
08-17-2006 09:35 PM
HatchBox
16
11-30-2003 06:24 AM
hahagasdcrx
13
06-18-2003 11:46 AM
Quick Reply: Car Shaking!
