Suspension & Brakes Theory, alignment, spring rates....
H22A in EG pass. side axle wobbling and shaking!!!???
Old Aug 14, 2006 | 09:26 PM
pcguy760's Avatar
Default H22A in EG pass. side axle wobbling and shaking!!!???
Today I finally installed my DSS Stage 3 Axles which I bought used from another member on here "prostock" - when we took the car out on the road it started shaking and vibrating REALLY BAD no matter what speed I was at. Like I had a flat on the pass. side.
Well I jacked it up on some stands and let the wheels turn in 1st and noticed that the passenger side was making a wierd thumping noise - I go look at it while my buddy keeps it running in 1st gear and it's moving up and down! Its like that pass. side axle is bent or something causing it to wobble because the whole pass. side suspension was moving up and down!!
Do you guys think its that Axle that is the problem or the tranny? Honestly I do not think it could be the tranny but I just wanna be sure. Tranny is M2B4 LSD btw...
Old Aug 15, 2006 | 11:26 PM
pcguy760's Avatar
Default Re: H22A in EG pass. side axle wobbling and shaking!!!??? (pcguy760)
Nm, problem found and fixed somewhat - is was the darn inner cv joint on the DSS Axle that was bent but cannot really be seen visually...
B16b-EJ8
16
Jan 9, 2007 06:01 AM
pcguy760
Aug 15, 2006 11:24 PM
poorman's type-r
Dec 3, 2005 03:45 PM
EKtypeRhaTcH
Jan 20, 2005 09:20 PM
