Loud Buzz at 2000-3000
Wondering if anyone has run across this. I have a 98 prelude, base, with about 60k on it. Between 2000-3000 rpm, and most noticed at 2400, there is a strong hollow sound coming from the engine. There is also a small vibration at 2400-2500. Does anyone know what this is?
Do you have an aftermarket header? If so check the flange, it mights be cracked. It is a common problem on aftermakert headers, notable on DC's. I have a buzzing sound at 2700-2800 and this fixed the problem.
-Jordan
-Jordan
Well, I'm not certain on H22 motors, but on F22 motors, Honda did note that there were some resonance frequency quarks at 2500rpm in the header...
Trust me, check the header flange. Its a common problem where the Flange cracks, and that fixed my rattling.
http://www.preludeonline.com/showthr...4&highlight=dc
There is also this thread also has some info. http://www.preludeonline.com/showthr...threadid=26119
Hope it helps,
Jordan
Hope it helps,
Jordan
specifically check timing belt tensioner
Paul
hope to god its not this, i just went through this.
Paul
giving it enough gas is hardly the problem. I have checked the header. The noise and vibration do come from inside the engine.
