CTR piston in a gsr motor?
Old Aug 14, 2006 | 06:51 PM
JFG Kevin's Avatar
Default CTR piston in a gsr motor?
I was just wonder if anyone actually messured what compression they got with CTR piston in a GSR motor?
Old Aug 14, 2006 | 07:01 PM
jennsGSR's Avatar
Default Re: CTR piston in a gsr motor? (aznstyler119)
any where from 13 or 14:1 put into a B17. ( rare motor) but our neighbor did it..
Old Aug 14, 2006 | 08:43 PM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Default Re: CTR piston in a gsr motor? (jennsGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jennsGSR &raquo;</TD></TR><TR><TD CLASS="quote">any where from 13 or 14:1 put into a B17. ( rare motor) but our neighbor did it.. </TD></TR></TABLE>
Is this accurate. I always hear diff numbers.. Can someone please make sure positively..
Thanks
Old Aug 14, 2006 | 08:55 PM
Danza's Avatar
Default Re: CTR piston in a gsr motor? (B18c5__Owns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c5__Owns &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks</TD></TR></TABLE>
Pretty sure its close to/around 13:1 due to differences in wrist pin location.
But I am in no way an expert on the subject
Old Aug 14, 2006 | 09:59 PM
realis9's Avatar
Default Re: CTR piston in a gsr motor? (Danza)
i have ctr piston in a b17a the pistons sticks out the block. To be safe I ran a cometic head gasket which is equivalent to 2 oem head gasket.
Old Aug 14, 2006 | 10:33 PM
Default Re: CTR piston in a gsr motor? (realis9)
so can anyone provide reall info on the USDM b18c1 or the JDM B18c
Old Aug 15, 2006 | 12:27 AM
JFG Kevin's Avatar
I've heard many differant numbers....b4 my actually built b4 i heard it was suppose to be 12.5...but i highly doult that cause my piston wouldn't have melted the way it did if it was. Now i hear they are 13.1 which is more believable but i have yet to find something to take the time to measure it for sure.
Old Aug 15, 2006 | 12:31 AM
justin.parker's Avatar
try using a compression calculator.
http://zealautowerks.com
edit: you might want to glance over in the all-motor forum. There are a couple ctr/pct piston threads that might help you out a little.
https://honda-tech.com/zerothread/1712124
https://honda-tech.com/zerothread?id=717928
Old Aug 15, 2006 | 12:56 AM
JFG Kevin's Avatar
Default Re: CTR piston in a gsr motor? (justin.parker)
wow...that calculator is actually pretty acturate....thx..
Old Aug 15, 2006 | 03:34 PM
yea i used the calculator from c speedracing
but i just wanted tomake sure
94typeR
May 26, 2007 11:59 AM
Jago
Jan 8, 2007 09:36 PM
DAintegra
Feb 14, 2005 10:28 AM
TypeR II
Jul 22, 2004 08:19 PM
SnkyPY
Mar 20, 2004 02:16 PM
