Fuel pump change, with motor swap .....did anyone have to swap a bigger pump for the motor swap
Old Aug 14, 2006 | 06:31 PM
4gencivicef9's Avatar
Default Fuel pump change, with motor swap .....did anyone have to swap a bigger pump for the motor swap
I did a b16 swap and I am running lean somewhat , just curious if anyone else has came across this problem??
Old Aug 14, 2006 | 07:06 PM
boostedblkef's Avatar
Default Re: Fuel pump change, with motor swap .....did anyone have to swap a bigger pump for the motor swap
yes your stock fuel pump cant handle the up in fuel from stock to b16
Old Aug 14, 2006 | 07:08 PM
90b16dx's Avatar
i have a stock fuel pump with an adjustable fpr and its doing fine
Old Aug 14, 2006 | 07:37 PM
SiR Inspired ED7's Avatar
i currently have a 1990 Civic Si Hatchback with stock b16 (5 million series) with a the stock 1990 Civic Si hatchback fuel pump, what should i look for to get or am i ok?
Old Aug 14, 2006 | 07:43 PM
well from my experience they don't hold up i change my motor to a zc with rail injectors and fpr with other mods to support and my pump failed out after 25 miles get a walbro 255 should hold up pretty well
now going lsvtec turbo with 1000cc sat injectors will need different again
Old Aug 14, 2006 | 08:16 PM
K20EF8's Avatar
I was running a 220whp K20 with the stock fuel pump and didnt have any problems with it for 10k km
Old Aug 14, 2006 | 08:33 PM
crxnj's Avatar
Default Re: (K20EF8)
yeah stock fuel pump is plenty..if you want to do an upgrade dont get that walbro junk (no offense)..get a dohc vtec pump from a gsr or type-r,99-00 si,etc..they flow almost twice then the others do ...134lph vs. 79 lph
note- it has to be rigged to fit into our tanks ...but maybe the 92-93 gsr fits perfect,,not really sure
Old Aug 14, 2006 | 08:44 PM
Default Re: (Mr.speaker)
So if i get a differnt fuel pump, could i just put it on and call it a day or will i have t be doing some adjusting with my fuel?
Old Aug 14, 2006 | 08:46 PM
crxnj's Avatar
Default Re: (SiR Inspired ED7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 &raquo;</TD></TR><TR><TD CLASS="quote">So if i get a differnt fuel pump, could i just put it on and call it a day or will i have t be doing some adjusting with my fuel?</TD></TR></TABLE>
what fuel pump do you have in mind? Some need adjustable fuel pressure regulators to get it back to stock fuel pressure
Old Aug 14, 2006 | 08:49 PM
Well, anything besides stock. Since i prolly dont get fuel i actually need. i'm going to have to test my fuel psi. what psi am i suppose to have?
Old Aug 14, 2006 | 08:54 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 &raquo;</TD></TR><TR><TD CLASS="quote">Well, anything besides stock. Since i prolly dont get fuel i actually need. i'm going to have to test my fuel psi. what psi am i suppose to have?</TD></TR></TABLE>
wit the vacuum hose off its ~ 38-40 on mine and i think all hondas,,, but the book has it something like 36-40 psi with the vacuum off ,,
Old Aug 14, 2006 | 08:57 PM
I'll have to look. cause i have a b16 in my complete 90 civic si, and it's not running the way it should be, atleast i think so...
Old Aug 14, 2006 | 09:00 PM
crxnj's Avatar
got any codes? whats it doing?
Old Aug 14, 2006 | 09:03 PM
Well, let's start off with. i have no o2 sensors connected and i'm not getting any codes. i smell like odor of gas fumes and i dont know where to start looking for the leak. my gas mpg is not very great.
Old Aug 14, 2006 | 09:06 PM
CRXBart's Avatar
Stock pumps are fine untill you get over 300hp. I thought I was having problems with my pump on my K20, but it turned out it was my filter clogging. Car sat for 3 years so I'm sure there was a little bit of crap in there. Cleaned out the element and flows great now. I did allready replace the pump with a walbro 255 hp, so now I'm good for cams, bigger injectors, and a full on IPS setup. Check your filter. If you do need a pump you can buy walbro 255's all day long on ebay for $99 shipped.
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 &raquo;</TD></TR><TR><TD CLASS="quote">Well, let's start off with. i have no o2 sensors connected and i'm not getting any codes. i smell like odor of gas fumes and i dont know where to start looking for the leak. my gas mpg is not very great.</TD></TR></TABLE>
what do you mean theres no codes? you mean the check engine light isnt on or the bulb on the ecu isnt blinking...Cause my check engine light bulb was missing when i 1st bought the car and it had me stumped...Having no o2 sensors connected will definenatly make the car run like **** and pig rich...
Old Aug 14, 2006 | 09:14 PM
Check engine light works, because my distributer recently gave out and it was throwing a code for that, i tried other stock unchipped ecu's and stil no check engine light or cel codes from the ecu.
Old Aug 15, 2006 | 02:08 PM
alright thanks....
si90rex
May 24, 2006 06:31 PM
erubio14
Nov 25, 2005 10:28 AM
bluecrxsi
Jun 5, 2003 06:35 PM
E-lude78
Jan 7, 2003 02:41 PM
