Qustion about using DIE tap kit
From: I Bet You Really Want To Know Where In, NJ, USA
My ball joint for the LCA is cross threaded
My question is will the tap work to fix these threads?
The nut goes in for like 4 spins on the threads, then just stops
Can this be fixed?? PLease let me kno
I'd make sure there isn't any dirt in the nut or on the balljoint, it's pretty damn hard to crossthread those things... especially 4 turns in...
I found out the size for this, its M12 x 1.25
I hate to sound stupid, but im just wondering..
Would I be able to us a hex die that is M12 x 1.50
Would the nut, not go in??
It might? The ball joint is exactly that... a joint. If you try and rethread the end of it, there is a possibility the joint itself will just rotate within the boot.
Any particular reason you are straying away from replacing the whole assemble? It builds character
(and breaks cheap c-clamps!)
lol character is what i dont have i guess. I got no loot to have a mechanic to do it and im not lookin foward to the trouble in replacing it myself
