Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ?
Old Aug 14, 2006 | 11:10 AM
thej0hnster's Avatar
Default Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ?
Numerous posts document the fact that Del Sol 4 wheel disc brake setups use the 1725 proportioning valves. The 1991 CRX Si 4 wheels disc brakes uses the 2040 Prop valve. It is reported that using the 4040 for stock fronts and upgraded rear discs is not recommended.
So which prop valve do I use?
Old Aug 14, 2006 | 12:01 PM
Tyson's Avatar
Default Re: Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ? (thej0hnster)
i didnt know the del sol had a 1725, nor did i know it even had rear discs.
the si with the 2040 also has slightly bigger front piston caliper. but even still, id use that if you have rear discs.
Old Aug 14, 2006 | 12:13 PM
I was researching a lot on proportioning valves and the Del Sol guys mentioned they had the 1725 valve on their 4 disc brake setups as OEM stock.
Old Aug 16, 2006 | 08:28 AM
Any other tips?
Old Aug 16, 2006 | 11:33 AM
gsxr1k05's Avatar
i have a 90 dx with the 94 teg rear swap, and stock crx disc up front. i swapped in the 94 teg booster and 1" master clinder and use the 40/40 with no problems. stops like a dream that you would not believe
Old Aug 16, 2006 | 11:34 AM
Tyson's Avatar
Default Re: Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ? (gsxr1k05)
40/40? do you have vtech too?
its 4040 like its vtec.
Old Aug 16, 2006 | 11:36 AM
gsxr1k05's Avatar
Default Re: Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ? (Tyson)
naw, no vtech.. i got g&e for my home phone hehe
Old Aug 16, 2006 | 12:07 PM
vtechrex's Avatar
tyson you are a queer. everyone knows what he means you dont have to flame him up for putting a slash in there if you arent going to give an answer that matters keep it to yourself
Old Aug 16, 2006 | 12:11 PM
Tyson's Avatar
Default Re: Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ? (vtechrex)
says the guy who's username is vtechrex.
Old Aug 16, 2006 | 12:17 PM
mxpx035's Avatar
Give him a brake it is that big of a deal to post a dumb comment <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">40/40? do you have vtech too?
its 4040 like its vtec. </TD></TR></TABLE>
But that is a Different story but Funny because it goes with your last post<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">says the guy who's username is vtechrex.
Old Aug 16, 2006 | 12:21 PM
Tyson's Avatar
Default Re: Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ? (mxpx035)
same ****.
get it right.
Old Aug 16, 2006 | 12:36 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechrex &raquo;</TD></TR><TR><TD CLASS="quote">tyson you are a queer. everyone knows what he means you dont have to flame him up for putting a slash in there if you arent going to give an answer that matters keep it to yourself</TD></TR></TABLE>
Nothing wrong with giving people the correct information to avoid confusion.
Old Aug 16, 2006 | 12:41 PM
vtechrex's Avatar
Default Re: Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ? (EL Vap133)
but its not like it maters they are the same numbers with a slash in there 4040 and 40/40 mean the same thing it is spliting hence the slash the presure 4040 to the front and rear
Old Aug 16, 2006 | 12:47 PM
Tyson's Avatar
but its not!
wtf does 40/40 mean? nothing!
unless you can decipher the meaning behind 1725, 3030, 3040 and 4040, then go right ahead and tell us. none of us have figured it out other than looking at trends, which in total arent consistent. hell, the OP question proves that.
thats why its wrong.
40/40 is jayZ's nyc club.
Old Aug 16, 2006 | 02:30 PM
The reason why I ask is that the 4040 was meant for an integra that has 10.3 front and 9 3/8 in the rear.
The CRX Si came with the 2040 With 9.5 in the front and 9 3/8 in the rear.
The Del Sol came with the 1725 with the 9.5 in the front and 9 3/8 in the rear.
Now I have a Civic Si with a stock 1725 with 9.5 in the front and would like to swith to the 9 3/8 integra, would it make sense not to change the prop valve since the Del Sol has it factory 1725?
Cheers you guy, and thanks.
F0B
delfast
10
Feb 22, 2009 07:20 AM
blks2k3
Suspension & Brakes
Jul 17, 2006 09:35 PM
teknics1
Aug 20, 2005 11:21 AM
s73
Aug 13, 2002 05:01 AM
