B20B vs B18B ?????????????????
Old Aug 14, 2006 | 08:57 AM
96LsBang's Avatar
Default B20B vs B18B ?????????????????
Well to start i had astock motor in my ls special edition then i swapped it out do to bottom end problems for a B20 but now my car seems so be running like a single i was wondering if somebody could explain why or how can i get it to run strong without putting to much money into it
Old Aug 14, 2006 | 09:02 AM
aznsins88's Avatar
im not sure what you mean but did u put in a b20 block and keep the ls head? if so you should have gained some tq becuase they use the same head but b20 has that bigger displacement. and the best bang for the buck nowadays is by turboing your car so yea...wat are your goals and plans first?
Old Aug 14, 2006 | 09:06 AM
96LsBang's Avatar
i swapped the whole motor and as far as plans i'm basically trying to get as much power without having to put much money into it
Old Aug 14, 2006 | 09:12 AM
aznsins88's Avatar
ok well your best bet would be turbo charging it and if u do do that then get the BEST TUNER in your area cuz if you got a bad tune...say bye bye to motor...its only gonna last as good as its tuner. plus if u put one together yourself you can prolly have a custom turbo kit for around 1500...just my .02
Old Aug 14, 2006 | 09:35 AM
96LsBang's Avatar
thanks for the advise
4thgenx42
Sep 25, 2006 04:15 AM
TJ99si
Sep 7, 2005 04:44 PM
4drferio
Jan 7, 2004 03:47 PM
whoDAT
23
Oct 7, 2003 02:17 PM
es four
Oct 29, 2002 09:50 AM
