little problem with h22 swap with the trans/body mount?
Old Aug 13, 2006 | 09:24 PM
bubblehead's Avatar
Default never mind problem solved thanks guys MODS DELETE PLEASE
got the problem fixed thanks again to all the help me out
thanks agian
Modified by bubblehead at 4:08 PM 9/14/2006
Old Aug 13, 2006 | 09:33 PM
Sleepy_Red_hatch's Avatar
Default Re: little problem with h22 swap with the trans/body mount? (bubblehead)
hmmm correct me if m wrong, but the H22 needs to have the tranny mount cut out like a K swap? ugh, im prolly wrong, either way, free bump
Old Aug 13, 2006 | 10:12 PM
bubblehead's Avatar
i guess your right, well at least that is what they previously did anyway when they installed the h22, and if i have to i'll just cut the ends off of the factory mount so as not to damage the paint, I GUESSSSSSSSSSS
thanks for the bump
Old Aug 13, 2006 | 10:46 PM
fkncivic's Avatar
Default Re: (bubblehead)
pm crxbart on here, he just did a swap for a guy with an eg(h22) he should be able to hook u up.
Old Aug 14, 2006 | 04:37 AM
CRXBart's Avatar
Default Re: (fkncivic)
There are lots of little issues that need to be addressed. I used the new Hasport mounts not sure what you have. You will indeed have to remove the passenger side mount bracket from the engine bay. That can be done a number of ways, such as using a drill, spot weld cutter, air chissel ect. The new mount will bolt in where the factory front roll mount on the pass. side. You will also need to dent your frame rail to clear the tranny. If you have a JDM h22 tranny w/ lsd, like I used, a dent isn't enough. I had to cut a notch out.
The fuel filter will need to be relocated, or as I reccomend replace your lines with an lines, and use a small low profile AN filter. It will get you allot more room in there. You will also need a slim fan. I don't think it is possible to retain power steering, we didn't anyway. The wiring is pretty basic. You will have to bolt your shock forks on the opposite side to clear the axles. The wiring, is basic, and then al you have to do is weld up some exhaust and your rolling.
Note: Hasport changed their mount design, and all ot of these issues were not issues before, but with the new generation mounts that give better axle geometry you have to do a few more mods.
Old Aug 14, 2006 | 09:55 PM
fkncivic's Avatar
Default Re: (CRXBart)
mrbh22
Oct 12, 2009 09:13 AM
fastwanabe
Feb 7, 2007 08:31 PM
JasonST
Mar 21, 2006 09:34 PM
Luserkid
Dec 9, 2004 10:07 PM
