running a different ecu from the motor
Old Aug 13, 2006 | 07:46 PM
nuklang's Avatar
Default running a different ecu from the motor
i was wondering if i run a SI(obd2) in a obd2 98 gsr motor will work.. because i cant seen to get a gsr ecu around here. i want my car out by this weekend.. so the si ecu is my last solution.
Old Aug 13, 2006 | 08:45 PM
pvt_awol's Avatar
I don't think that it will work for you, the Si ecu is OBD2b, and your GSR is OBD2a. There is an extra plug on the Si's harness.
If, you were to get it to work, it would make your VTEC engage at 5600 rpms (or whatever) and your secondary butterfly valves wouldn't open on your GSR intake manifold. (stock GSR is 4500 VTEC, and 5600 butterflies)
Old Aug 14, 2006 | 07:32 PM
nuklang's Avatar
Default Re: (pvt_awol)
well i'm running the gsr in my 99 civic hatch. and using the civic stock harness to wire up the 98 gsr motor.
Old Aug 14, 2006 | 07:58 PM
b18ccivics's Avatar
Default Re: (nuklang)
if you are running a 99 harness then it will work but i dont recomend it get a gsr ecu
GSR936
May 12, 2010 07:15 PM
boostd92
Aug 18, 2006 10:43 AM
angelo1683
12
Jul 5, 2006 04:29 PM
juniestyle
Apr 24, 2006 08:38 AM
Trust No One
Feb 3, 2003 04:12 PM
