Well gathered some parts(auto-manual) just a check up
Old Aug 13, 2006 | 04:00 PM
uszcrx's Avatar
Default Well gathered some parts(auto-manual) just a check up
Slowly planning out my auto to manual swap on my 1996 green sol just making sure i cover ALLL my bases before i attempt to start!
OK so far I've acquired the following:
From a 92-95 civic-
Trans
ECU(yea i know wrong one)
Clutch + brake pedal
master cyl and some lines ?
starter
misc mounts/stabilizer
From ebay-
del sol S/si shift linkage + ****
Manual p2p d16y8 ecu frmo 97 ex
I plan on getting a clutch kit because the clutch on the tranny is no good.. but this is what i THINK i still need to get-
d16y8 manual intake manifold and throttle body.
2 wire IACV
What am i missing?? :-) any help is appreciated..
Also what parts of the swap can i do BEFORE i actually have to stop driving the car.. pedals?? Just trying to make this as smooth as possible because me w/ no car = no job = no $ for other parts haha
Thanks!
Old Aug 13, 2006 | 06:28 PM
byronl's Avatar
Default Re: Well gathered some parts(auto-manual) just a check up (uszcrx)
you could put on the clutch lines
Old Aug 13, 2006 | 07:42 PM
Sleepy_Red_hatch's Avatar
Default Re: Well gathered some parts(auto-manual) just a check up (byronl)
since when does the clutch bolt to the tranny?
Old Aug 13, 2006 | 07:54 PM
ekhunter's Avatar
i have del sol b-series shift linkage, if you need it, its a very hard to get item.
Old Aug 13, 2006 | 08:03 PM
Default Re: (ekhunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhunter &raquo;</TD></TR><TR><TD CLASS="quote">i have del sol b-series shift linkage, if you need it, its a very hard to get item.</TD></TR></TABLE>
since he got a del sol s/si linkage, i'm willing to bet that he has a D-series inside.
Old Aug 13, 2006 | 09:12 PM
uszcrx's Avatar
Default Re: (Sleepy_Red_hatch)
haha yes, it is my daily driver so low boost turbo is all she gets :-) but this is the first step.. :-)
I dont see where i said the clutch bolted to the tranny.. but i will be putting in the pedals over the weekend.. as far as the lines .. i only have them from 92-95 civic.. will i have to add my own ss line for any of them??
thanks!
Old Aug 13, 2006 | 09:39 PM
Default Re: (uszcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx &raquo;</TD></TR><TR><TD CLASS="quote">
i do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx &raquo;</TD></TR><TR><TD CLASS="quote">I plan on getting a clutch kit because the clutch on the tranny is no good.. </TD></TR></TABLE>
right...HE-A!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uszcrx &raquo;</TD></TR><TR><TD CLASS="quote">as far as the lines .. i only have them from 92-95 civic.. will i have to add my own ss line for any of them??
you should be alright as long as you have the EG hardlines + softline....oh SNAP! did you get a clutch slave cylinder?
edit#2 btw: you can do the pedals/master cylinder/hardline/softline/slave cylinder filling with fluid and bleeding system (dont forget to benchbleed the MC)/IM/TB without putting the car to rest. each of those jobs individually dont take much time. and then swap in the tranny when you have the time, just make sure the Slave is tied up so it doesnt bounce around while you drive
ninja edit! this is post #1700!!
Old Aug 14, 2006 | 05:23 PM
uszcrx's Avatar
Ok good start thank you.. I have vacation time in 2 weeks i think i'll try the swap then.. but i really have to make sure i have everything! haha
Its still unclear after reading umteen hundred posts on WHAT throttle body and WHAT IM is compatible for this swap.. is it d16y8 manual only? or can i self tap into these pieces?? Most post linger around the answer and its not clear.. if there is someone that can give answer some of my questions i would appreciate it!! through email or something! :-)
PS anyone in NEW JERSEY wanna help out sometime the week of the aug 27-sept 2
free beer haha
Old Aug 15, 2006 | 02:59 PM
uszcrx's Avatar
Bump got some helpful info via PM's .. still looking for a throttle body.. and potentialy a manifold.. if not I will attempt to drill out my own!! :-X
OTHER then those items does anyone see anything that sticks out that I'm missing
p.s. good clutch kit for about 200 HP?
Old Aug 16, 2006 | 04:10 PM
uszcrx's Avatar
Bump plus update
From a 92-95 civic cx -
Trans eww bad ratio- in process of either gettin ex trans or FD and gears for EX
starter
From ebay-
d16y8 manual intake manifold(might just tap my own) and
MANUAL throttle body from a newer civic i think works.. and from integra LS i've been told also.. .
If anyone knows for sure.. i think it has to have 2 wire iac connection?? not 100% sure but thats what i got so far... do autos have an iac? lol
2 wire IACV
Ps. I bought an antenna.. what a pain install
What am i missing?? :-) any help is appreciated.. i really think i'm missing SOMEthing haha
Old Aug 16, 2006 | 08:06 PM
uszcrx's Avatar
Bumpppiddy anyone remember that part that they forgot while doing this swap?? cuz i dont wanna have that moment? ;-)
Old Aug 17, 2006 | 05:27 PM
uszcrx's Avatar
Bumpppppp :-)
Old Aug 18, 2006 | 09:22 AM
uszcrx's Avatar
bumpinnn.. anyone have a pic of the longer flywheel bolts? and how to tell if i have the right ones??
Old Aug 27, 2006 | 06:43 AM
uszcrx's Avatar
bump swap happening this week.. do i need longer bolts for my flywheel?? I dunno if i have them i will post pics of my parts on tues
delslow45
24
Dec 17, 2009 07:30 AM
crvpimpin
Oct 7, 2006 09:55 AM
Boarder03
Mar 30, 2006 07:06 PM
Pocket_Rocket
Aug 12, 2005 04:40 PM
