FS:H22A4 Block OS type s pistons
Old Aug 13, 2006 | 02:58 PM
boostinh22
Guest
Posts: n/a
Default FS:H22A4 Block OS type s pistons
H22A4 (base) block bored/honed .25 over for oversized Type S pistons
Oversized Type S (11.0:1 cr) pistons
Eagle H22 rods
balanced/micropolished H22a4(55mm mains) crank
main girdle.
block,pistons/oem rings, rods, crank, main girdle(disassembled)
$750 picked up.
pistons/rings and rods- $350 plus shipping
block only- $400 picked up
the whole setup has about 5k miles on it since the build. All machine work was done by Jim Justice at Justice Racing Engines in Frederick, MD.)(check him out http://www.justiceracingengines.com/)
the block was bored, honed, decked, and align honed. i can get a spec sheet for the amount it was decked as well as the entire build(clearances and so forth)
I'd like to sell it complete. there won't be bearings included and it will be disassembled. i think the oil pump went bad and the bottom end was starved of oil. the crank was micropolished and balanced but may need to be polished again since the bearings were slightly damaged due to the lack of oil.
***let me say this again....the only thing that's damaged whatsoever, is the crank. it's very slightly scarred.****
Modified by boostinh22 at 7:48 AM 8/16/2006
Modified by boostinh22 at 8:04 AM 8/24/2006
Modified by boostinh22 at 7:44 AM 9/13/2006
Modified by boostinh22 at 9:01 AM 9/14/2006
Old Aug 14, 2006 | 04:33 PM
boostinh22
Guest
Posts: n/a
Default Re: FS:H22A4 Block OS type s pistons (boostinh22)
up
Old Aug 16, 2006 | 03:48 AM
boostinh22
Guest
Posts: n/a
bump
Old Aug 16, 2006 | 03:10 PM
boostinh22
Guest
Posts: n/a
up
Old Aug 18, 2006 | 03:28 PM
boostinh22
Guest
Posts: n/a
up
Old Aug 21, 2006 | 03:55 AM
boostinh22
Guest
Posts: n/a
up
Old Aug 21, 2006 | 05:39 PM
boostinh22
Guest
Posts: n/a
up
Old Aug 28, 2006 | 04:17 AM
boostinh22
Guest
Posts: n/a
bump
Old Sep 13, 2006 | 03:44 AM
boostinh22
Guest
Posts: n/a
lowered price of rods/pistons
Mike@CCT
Mid-Atlantic (Sales)
Mar 2, 2010 09:52 AM
Mike@CCT
Feb 23, 2010 09:51 AM
TcUiRvBiOc
May 16, 2007 01:29 PM
salt
Mar 2, 2006 02:56 PM
