having problems with putting new axle in, need help asap
Old Aug 13, 2006 | 02:50 PM
iphatcrxi's Avatar
Default having problems with putting new axle in, need help asap
i just bought a brand new driver side axle and i am now puting the axle nut back on and when i go to torque it down nothing will spin, the axle, the rotor, nothing, am i doing something wrong?
Old Aug 13, 2006 | 02:52 PM
92integra_gs's Avatar
did you make sure that the grooves in the tranny side is in properly... ???
Old Aug 13, 2006 | 02:54 PM
iphatcrxi's Avatar
Default Re: (92integra_gs)
yes im pretty sure because when i loosen the nut everything moves
Old Aug 13, 2006 | 03:04 PM
how hard are you spinning the axle when you take the nut out.. effortless?
i would actually test this out... have someone kinda try to stimulate drive while you are in jack stands ... then see if that axle will move..
if it dont move its not in properly if it does move its in..
Old Aug 13, 2006 | 03:07 PM
iphatcrxi's Avatar
im using an air tool not sure of the psi... but i have to use the tool to get it off
Old Aug 13, 2006 | 03:25 PM
iphatcrxi's Avatar
Default Re: (iphatcrxi)
it takes a little effort, more than the passenger side
Old Aug 13, 2006 | 03:49 PM
iphatcrxi's Avatar
should i tighten it anyway and try to drive it on jack stands?
Old Aug 13, 2006 | 05:48 PM
iphatcrxi's Avatar
ok i took this ring off and now when i tighten the nut it will spin, i think it was for abs. now i have another problem, i cant get the lower ball joint nut to line up so i think the axle is sticking out too far, but i compared it to the stock axle and its actually shorter..
EG6_978
Mar 18, 2009 02:38 PM
Endo-land
Sep 5, 2007 06:42 AM
dynamo
13
Nov 14, 2005 08:22 PM
JDM96SpecCTR
13
Dec 6, 2004 01:34 PM
Feb 19, 2004 08:54 PM
