Changing Coolant in 5th gen
Old Aug 13, 2006 | 10:38 AM
loudsubz's Avatar
Default Changing Coolant in 5th gen
I have done it in my 94 civic before, and removed the big 19mm drain bolt on the back of the block, but it was a PITA to remove.
So my question is, does it really need to be removed to drain the coolant, or if I do a flush with a garden hose should I be able to clean it out just as well without removing the drain bolt on the back?
Old Aug 13, 2006 | 02:00 PM
onefastrx7turbo's Avatar
Default Re: Changing Coolant in 5th gen (loudsubz)
yea when I did mine I didnt drain the block either. As long as you flush it out you are good. try to get out as much of the garden hose water as you can. That water HATES aluminum.
Old Aug 13, 2006 | 04:58 PM
loudsubz's Avatar
Default Re: Changing Coolant in 5th gen (onefastrx7turbo)
good to know
thanks
Old Aug 13, 2006 | 07:06 PM
phateless's Avatar
dunno about the lude, but my teg stock radiator has a drain plug on the bottom somewhere. pull all that plastic shrouding from the bottom of the car and poke around under there, see if you can find what i'm talking about.
Old Aug 13, 2006 | 08:25 PM
TruNinja619's Avatar
Default Re: (phateless)
just take out the drain plug from the radiator.. that'll suffice...
Old Aug 14, 2006 | 03:13 PM
loudsubz's Avatar
Default Re: (TruNinja619)
yeah I know about the drain plug on the radiator, but it also mentiones the plug on the back of the block, so i was just curious.
thanks.
atikovi
Oct 7, 2010 05:49 PM
xXViperXx
May 6, 2010 06:39 AM
sinister357
Apr 29, 2005 05:20 PM
TypeRuz
Dec 5, 2003 09:15 PM
You_Get_Vapors
Jun 16, 2003 09:17 PM
