I should know this but.....
Guest
Posts: n/a
Is there a drain plug on the block that I have to remove to drain the coolant, or can I just undo the radiator drain? I dont have a torque wrench, will I have to torque the block plug if removed? Where is the block drain plug? B16
Guest
Posts: n/a
yeah it should just push all the old coolant out....when u do the new....it'll run the new thru...push the old out.....run ur car for a few days to get the new stuff in....then drain again and redo
they might have some solvent u put in at advanced auto or something to clean the insides of the block that u put in ur coolant....im not gonna say for sure but they might
opening up the block plug will release LOTS of coolant. but its behind the exhaust manifold. u should be able to access it with a wrench. its worth the time to open it up if you can. I dont like having 16 gallons of coolant/water to dump.
Guest
Posts: n/a
Thanks guys, It looks like it is to the left or the header. I dont have a socket the big or a torque wrench so im just gonna flush it with water till it runs clean. Then ill fill her up with Honda Anti freeze. Thanks for the replies.
Guest
Posts: n/a
LOL I didnt get to it today but I prolly will tomorrow. I did recharge my K&N and check the plugs. I think Ill change the coolant and tranny fluid tomorrow. I didnt have any place to dump the coolant and the filter took to long to dry. Thanks for all the help. Next brake job.grrrrrr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerogravity »</TD></TR><TR><TD CLASS="quote">yeah it should just push all the old coolant out....when u do the new....it'll run the new thru...push the old out.....run ur car for a few days to get the new stuff in....then drain again and redo
they might have some solvent u put in at advanced auto or something to clean the insides of the block that u put in ur coolant....im not gonna say for sure but they might</TD></TR></TABLE>
What a waste of coolant and time. I bet I can flush my system faster then you can...
I don't mean to bust some heads arround here, but common people!!! Drain the coolant from the bottom of the radiator. Take your thermostat housing off (2 bolts), take the thermostat out and put the housing back on and put the bolts on... hand tight is ok. Next get inside the car and move your heater control lever to the HOT position. This opens up your heater core that should be flushed out as well when you do this to properly clear the system out. Now take the top radiator hose off and point it down so it will drain under the car. Next get your water hose you used yesterday to wash your car and stick it into the radiator opening where you took the upper hose off. Turn on the water and watch all that **** come out of your coolant system.
Work smart people and not hard!!!
Yes, with the car off... lol
You take the thermostat out because when it's cold... (the coolant and water) the thermostat closes. If it's closed you can't run the water throught the whole system. It'll stop at the thermostat. Oh yeah... put the thermostat back in when you're done obviously. And while you're at it... since you've got the thermostat out anyway, take it inside your house and fill a small pot with water and put the thermostat in it... then put it on the stove-top and bring the water up to temp. See... that's how a thermostat works.
Oh yeah... it does that cuz it's magic... don't ask.
btw, if you've had the thermostat in the car for a while might as well get a new one and a new thermostat gasket. It's not expensive and since you're in there anyway... just change it.
atikovi
Oct 7, 2010 05:49 PM
TypeRuz
Dec 5, 2003 09:15 PM
