can i use my Civic CX Distributor on my B20VTEC Swap? How bout my CRV distributor?
guys.,
can i use my CX Stock Distributor on my B20VTEC Swap? Or can i use the B20 CRV Distributor on my B20VTEC Swap? Or am i gonna have to buy a gs-R (94-95) distriubutor?
Thanks.
vnt
Thanks.
vnt
if you are using a b series ecu then i think you need to use a distibutor from the same setup, i dont think it matters that the distributor came off a vtec motor or not, but it probably would be better. i will be using a 93 gsr dist on my obd1 b20vtec setup
i will be using a chipped p28 also, and was told that i could use any obd1 integra dist...vtec or nonvtec
no and no
*edit* you need the gsr one or b16a one, obd1 if your car is 92-95 and you are using an obd1 engine harness.
[Modified by Jackson, 7:57 PM 4/25/2002]
i wonder if i can repin the B20 Distributor, and plug it up to my CX Harness? Mnnn!
val t.
val t.
Guest
Posts: n/a
no you cannot use a cx distributor on a DOHC engine. any sohc d-series distributor will not work.. it mounts different.. the shaft and the housing is different. But everything esle on the distributor is the same. But a b-series distributor can be interchanged to work with any other b-series motor, but might have to chop off a leg to clear the vtec solenoid if you planning on using it on a vtec motor.
oh ok...thanks for the advice!
i'm gonna get me a gs-R distributor in that case!
vnt
vnt
dmakarov
Northwest (Sales)
Dec 6, 2006 09:25 PM
adrynalinewhore
Feb 27, 2006 10:29 PM
Sirex
Mar 18, 2003 07:31 PM
