Glowing header???? help needed!!!!!!!!!!!!!!!
Old Aug 12, 2006 | 11:18 PM
SLO Sol's Avatar
Default Glowing header???? help needed!!!!!!!!!!!!!!!
i drive a 92 honda civic Si... d16-z6 has short ram intake on it. cruised tonight on the highway and around town one of the guys i was with blew his exaust piping stopped so he could fix looked under the hood of my car and my header was bright red... never has done that before i wasnt driving the car too hard shifts around 6. are there anyways i can cool my car down enough that when i drive my car i dont have a cherry
Old Aug 12, 2006 | 11:20 PM
b00sted_hatch's Avatar
Little Hercules
Default Re: Glowing header???? help needed!!!!!!!!!!!!!!! (D-money 92si)
um..doode its your header! your EGT temp is gonna be hella high! were you ragin the **** out of your car when this happened?
Old Aug 12, 2006 | 11:22 PM
SLO Sol's Avatar
Default Re: Glowing header???? help needed!!!!!!!!!!!!!!! (b00sted_hatch)
my coolant temp was normal. and i wasnt driving too hard i think i hit 95 the highest and before i parked for about 45 mins i was doing 35-40
Old Aug 12, 2006 | 11:27 PM
Little Hercules
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">my coolant temp was normal. and i wasnt driving too hard i think i hit 95 the highest and before i parked for about 45 mins i was doing 35-40</TD></TR></TABLE>
im sorry but i dont buy it. im boosted and my EGT temps are a lot higher and i have to boost the **** out of my car to even get my turbo starting to glow red.
Old Aug 12, 2006 | 11:29 PM
SLO Sol's Avatar
EGT? btw its the stock header
Old Aug 12, 2006 | 11:32 PM
tempsohc's Avatar
clogged cat...seen it before...
Old Aug 12, 2006 | 11:35 PM
Little Hercules
Default Re: (tempsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">EGT? btw its the stock header</TD></TR></TABLE>
EGT = exhaust gas temperature. could be a clogged cat i ono. i still think you were ragin
Old Aug 13, 2006 | 09:59 AM
SLO Sol's Avatar
Default Re: (b00sted_hatch)
i dont belive i have an exhaust temp sensor...regardless what are some quick ways i can cool it down... since i have alot of air going in, could it be back pressure since i have a stock exhaust system?
Old Aug 13, 2006 | 10:08 AM
Max Kling's Avatar
Its prolly your cat. On my old accord I had a clogged cat so bad that at idle when the car was parked in the grass it started to catch the grass on fire.
Old Aug 13, 2006 | 10:11 AM
SLO Sol's Avatar
Default Re: (Max Kling)
where to find a cheap header back exhaust that doesnt sound like a weedwhacker on nitrous...
spoonsiz88's Avatar
Default Re: (D-money 92si)
most likely back pressure from either clogged cat or exhuast muffler may need to be replaced , like most ppl said u could have been beating on it a little to hard, although it is normal for aftermarket headers to glow. u can prob improve this with exhaust wrap, aftermart cooling fan, maybe a vented hood, or aftermart front air damn if your really worried about it. also a longer ram CAI will pick up cooler air
Old Aug 13, 2006 | 10:19 AM
spoonracer84eg's Avatar
Default Re: (spoonsiz88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">i dont belive i have an exhaust temp sensor...regardless what are some quick ways i can cool it down... since i have alot of air going in, could it be back pressure since i have a stock exhaust system?</TD></TR></TABLE>
You dont have to have an EGT sensor to have an EGT lol. Its a cast iron header and they tend to get red hot. I suppose it could be a clogged cat but if the cat was clogged the car would run like ****.
Old Aug 13, 2006 | 11:43 AM
Tomslide50's Avatar
Default Re: (spoonracer84eg)
It is not normal for your exhaust manifold to glow red, no matter what people tell you. It is either from retarded timing, or a clogged cat.
spoonsiz88- Exhaust wrap insulates. This would make your egt's go up. Aftermarket cooling fan? First of all- he said his coolant temps were normal(you should really read what the person says before replying), and secondly- your engine would overheat, blow a head gasket, and shut off, and it still wouldn't make your header glow red from coolant temps. A vented hood or aftermarket front air dam? This doesn't happen to normal running civics with stock engine bay air flow, so how is spending money on aftermarket aero parts a better solution than just fixing the problem? Same thing for the cold air intake. The egt temp drop from the colder intake charge is negligible compared to the kind of temps it takes to make the manifold glow.
I'm sure some people will argue that they've seen headers glow on a dyno, but he said he was going 90mph before he looked at it. I'd say he has adequate air flow to cool the header enough to where it shouldn't be glowing if everything was working correctly.
D-money 92si- The way to check for a clogged cat (or any kind of exhaust restriction) is to hook a vacuum gauge to your intake manifold and blip the throttle. After you let off the throttle the needle should return to full vacuum quickly. If it doesn't go back to reading full vacuum almost immediately then you have an exhaust restriction.
Old Aug 13, 2006 | 12:07 PM
SLO Sol's Avatar
Default Re: (Tomslide50)
thanks checking that in a few
Old Aug 13, 2006 | 02:03 PM
Syndacate's Avatar
Sounds like it's a clogged cat converter, I've seen this quite a few times, too much heat builds up inside your manifold/header.
EDIT:
I'm not sure what's legal or not in IL but what I do know is when you replace that cat, replace it with a high flow cat. It'll free up some room but it'll keep your backpressure good.
Old Aug 13, 2006 | 04:10 PM
Tomslide50's Avatar
Default Re: (Syndacate)
"it'll keep your backpressure good."
Backpressure is in no way beneficial to making power, if that's what you're implying. The backpressure = torque myth comes from small pipes increasing low speed velocity and producing more torque down low. Backpressure robs horsepower. Any time your motor has to work harder to get exhaust out, you lose power. The only reason to have even a high flow cat is for emissions.
Old Aug 13, 2006 | 05:12 PM
tempsohc's Avatar
this true..but a straight headeer will always make more power/torque than a full exhaust system...proven time and time again.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomslide50 &raquo;</TD></TR><TR><TD CLASS="quote">"it'll keep your backpressure good."
Old Aug 13, 2006 | 05:18 PM
FalkenSiR's Avatar
Running lean can also lead to this. Doubt it if your engine is stock w/boltons...
Old Nov 6, 2025 | 07:23 PM
cesark619's Avatar
im having the same issue right now. I’m doing a mini swap D15B with a D16Y8 head. Can even get the car out cause my headers get really hot and start glowing super bright red.
any help
pinoy_Si
Honda Civic (2006 - 2015)
21
Nov 7, 2013 10:57 PM
JDM97dc2R
Mar 4, 2007 02:10 PM
HondaTech101
Dec 20, 2006 03:08 PM
X2BOARD
Jun 22, 2004 04:13 PM
SpoonFedHatch
Apr 26, 2004 02:34 PM
